Spare plug in engine bay???? Car won't start - MINI Cooper Forum
post #1 of 7 (permalink) Old Mar 24th, 2014, 08:29 AM Thread Starter
Local Time: 05:46 PM
Question Spare plug in engine bay???? Car won't start
Managed to get the engine back together this weekend after a full engine rebuild, on putting it all back in the car I'm left with a plug I can't find where it goes!! It's down by the thermostat area about 10" long from main loom it has a black male plug with one blue and yellow wire and one green an purple.
The starter motor is not engaging at all I have checked all the wiring to it seems fine scratching my head a bit at the moment
Any help will be much appreciated
johnd-mkiv is offline
post #2 of 7 (permalink) Old Mar 24th, 2014, 09:52 AM
Quoted: 53 Post(s)
I havent got a Gen 1 manual, but the Gen 2 manual for wires blue and yellow it says Valvetronic servo motor, dont know if its the same on yours?
The Nun is offline
post #3 of 7 (permalink) Old Mar 24th, 2014, 11:44 AM Thread Starter
Not sure what that is does gen 2 have vvti?
post #4 of 7 (permalink) Old Mar 24th, 2014, 02:48 PM
Local Time: 04:46 PM
Hi ya
Hard to say but it might be the crankshaft position sensor on the front of the engine block just under the water pump around where the dipstick tube goes in to the block but I think that plug is grey but can remember
Only other things around there really is throttle body, map sensor, water temp, lamba sensors,
Have you got a diagnostic tool you can run a test on see what sensors are working and what are not
I think my money is on the water temp sensor it's hard to see it just to the rear of the thermostat housing below the rear hose
Can you see what colours the wires are
Hope this helps
marque is offline
post #5 of 7 (permalink) Old Mar 24th, 2014, 04:16 PM Thread Starter
Crank sensor I left on the loom that's in its place, map sensor is plugged in, water temp sensor also plugged in.
Now look g into possibility of it being clutch switch??? Thing is car started before with no need to put the clutch down?? Would an 03 mini have this feature or is it for later models?
John
post #6 of 7 (permalink) Old Mar 25th, 2014, 10:37 PM
Little use in knowing what the plug is but my 03 does not need clutch down to start.
Ant54 is offline
post #7 of 7 (permalink) Old Mar 26th, 2014, 04:03 PM
BLIKSEM (my brg/brg mc)
cristo's Avatar
Local Time: 11:46 AM
Quoted: 25 Post(s)
United States Male View cristo's British Racing Green & Body Color 1st Gen MINI Cooper Profile
Garage
My 03 does.
cristo is offline
MCS Engine noise when cold CBCooper Second Generation Faults & Fixes 2349 Mar 30th, 2016 10:09 PM
TWINI - Twin engine R53 Endurance Race Car pooper MINI in Motorsport 5 Aug 7th, 2015 11:22 AM
Please help! My car won't start & makes clicking noise... 2003 Mini Cooper Tyna General Discussion 3 Feb 1st, 2014 10:38 PM
Car starts, runs for a short period and begins to sputter out, then stalls. Ideas?? ledfrog Maintenance & MINI Care 4 Oct 27th, 2012 04:33 PM
URGENT - HELP/ADVICE NEEDED FOR R56 Mini Cooper S 2007 LadyUK Second Generation MINI Cooper S 18 Oct 23rd, 2012 07:29 PM
