Cooper S Blowing Exhaust - MINI Cooper Forum
post #1 of 7 (permalink) Old Mar 26th, 2014, 09:27 PM Thread Starter
Local Time: 12:12 AM
Hi guys, only had my r53 mcs a month or so, basically everything has been fine, then went i took it for (admittedly quite a high speed ) run down the motorway for a commute today, I got out and noticed that to the left of the exhaust tips, a bit of that plastic trim had a hole melted right through it.
I pinpointed the blow, its coming from my backbox, so I will obviously need to get a new one, but I have two questions about it.
1) The black trim that doesnt look like its actually a part of the bumper itself, is there anywhere I can get that part? Or does the whole bumper need replacing? Sorry about the newbieness I'm honestly not too sure whether that black trim just clips off or not sorry!
2) I was considering changing backboxes anyway, just something to give the car a bit more of a suited sound.. bit deeper, like a jcw backbox. Does anyone have any reccomendations for new backboxes (I've heard about Sportex being quite good) and is there anything else I need to consider when changing my backboxes on the car? Not 100% sure how the exhaust system actually works under a mini, sorry about the newbieness
If you dont get what I mean cause my explanation is probably terrible, I'll put a couple pictures up tomorrow when its light.
Thanks in advance
Aaron
Azamoa is offline
post #2 of 7 (permalink) Old Mar 27th, 2014, 06:13 PM
Hi ya
Depending on which back box has gone a good cheep mod to do is a "one ball mod"
Basically re routes the exhaust and deletes one box. See photos GTTuning sell the kit or if you have a good exhaust place near you it will be easy for them to do very easy job.
car sounds better but not loud more pops and bangs :-)
left picture is standard set up right is with one ball mod
I am not 100% on your trim problem but is it item 1 on this link. if so there not much from bmw 30 ish
RealOEM.com * BMW R53 Cooper S Trim, decor elements, rear
hope this help
ID:	171594   Click image for larger version
marque is offline
post #3 of 7 (permalink) Old Mar 27th, 2014, 09:29 PM Thread Starter
Thanks for replying
The trim I mean is the diffuser, I couldn't remember the name (noobie error) but figured it out eventually and have ordered one so thats fine
Regarding the exhaust, that gtt one ball re-route pipe looks and sounds brilliant. Absolutely ideal for what I want from the car so thanks for suggesting that.
Only downside is that the blow is coming from the backbox on my passenger side, and from those pictures and ones I've been looking at of the underside of the car, its the backbox on the drivers side that needs to be removed for this mod if I'm correct?
Thanks again
Azamoa is offline
post #4 of 7 (permalink) Old Mar 27th, 2014, 10:03 PM
Hi ya
That's a shame but it's still do able you can get just the left hand box
RealOEM.com * BMW R53 Cooper S Exhaust system, rear
It's around the 230 ish mark new but if you contact a breakers someone like mini matt they will be able to supply just the box, you need if you tell him what your doing :-)
MiniMatt|BMW|MINI|Modifications|Parts|Spares|Servi ce|Tuning|Repairs|Racing
Mini One and Mini Cooper Breakers, used BMW Mini One/Cooper car parts and spares
Hope this helps
marque is offline
post #5 of 7 (permalink) Old Mar 27th, 2014, 11:13 PM
Hi ya
just spotted this if it's any help
R53 exhaust
Hope this helps
marque is offline
post #6 of 7 (permalink) Old Mar 27th, 2014, 11:44 PM Thread Starter
Very helpful, thank you.
I've emailed MiniMatt to inquire about the box because I'd rather avoid getting the whole system if possible, for what it's worth, for that kind of price, I may consider pushing the boat out and getting an aftermarket system.
God, such hassle just for a small blow in the box haha
My last question to you is, what aftermarket complete system would you recommend that won't be too too loud?
Azamoa is offline
post #7 of 7 (permalink) Old Mar 28th, 2014, 01:05 PM
"My last question to you is, what aftermarket complete system would you recommend that won't be too too loud?"
Hi ya
there are some good options out there depending on budget and you future goals with mods and performance.
You have
JCW
Milltek
Janspeed
Scorpion
Quicksilver
Playmini
Jetex
Bora
OBX
Supersprint
And the list goes on, there are some good drive buys on youtube if that's any help.
The price ranges go from 250-300 ish to well into the thousand pound mark
Keep an eye out in the classifieds and ebay sometimes there are some good deals to be had
Hope this helps
marque is offline
mini cooper sd exhaust west coopersd MINI Cooper Diesel 0 Jan 22nd, 2014 09:20 PM
Cooper sd exhaust knowlesy20 Second Generation MINI Tuning 0 Nov 12th, 2013 05:37 PM
Help Needed 2002 Cooper S Exhaust Replacement Nippy First Generation MINI Tuning 1 Aug 1st, 2013 11:42 AM
MINI COOPER S Convertable 53plate Exhaust problem archerluke Second Generation MINI Suspension 1 Mar 31st, 2013 05:54 PM
Mini Cooper s rear exhaust on Cooper D Minilazz Second Generation MINI Exterior 0 Feb 17th, 2013 06:33 PM
