Cooper S Engine Rebuild - MINI Cooper Forum
post #1 of 2 (permalink) Old Apr 18th, 2014, 07:44 AM Thread Starter
Local Time: 06:37 PM
England Cooper S Engine Rebuild
Hi I am in the process of rebuilding my 2003 Cooper S,
My engine has been completely stripped down, new piston rings , reground crank etc.
I am in the process of setting up the timing chain Crank to camshaft, can anyone help, other than the manufactured marks (arrows) on the sprockets and the copper marks on the chain. I am not convinced I have the cam and crank in the right position,
everything I have read about refers to marking the pulleys when you strip it down, but I don't have these marks.
My concern is I am a tooth out or that the camshaft is 360 out sounds crazy I know.
Just want some conformation that what I am doing is right!
Adam (Northants)
budgie2014 is offline
post #2 of 2 (permalink) Old Apr 18th, 2014, 11:49 PM
Local Time: 05:37 PM
Hi ya
Cam timing is easy on the w11 ( oil pump cover off )
on the lower cam chain sprocket there are two dots they look like center punch dots set that around the 6 o'clock position.
On your cam chain there are two copper coloured links align then with the two dots.
Pull the cam chain up with your finger, you will see an arrow looks like a triangle on the cam sprocket, align that with the single copper coloured link at the top rotate your camshaft and align the locating pin on the cam with the top cam sprocket.
Torque up the cam bolt, then fit you rocker shafts and arms. Be carefully installing the rocker arm it easy to damage the lash caps and the nylon holders.
Hope this help
marque is offline
R52 Mini Cooper S Convertable - Damage to Engine Mount Point - Help! suhailrehman Maintenance & MINI Care 6 Mar 22nd, 2014 06:16 PM
Mini Cooper s engine issues jakvette General Discussion 0 Feb 12th, 2014 06:49 PM
Oil consumption Mini Cooper s N18 engine peterhellawell Maintenance & MINI Care 1 Jan 24th, 2013 09:11 PM
