Tunning a mini cooper Saround ESSEX??
2K views 1 reply 2 participants last post by  marque
#1 ·
My mini is just about run in after a full engine rebuild, where can you recommend around the Essex area to have this remapped:cool:
its running
new engine, cp forged pistons, newman cam
uprated supercharger pulley
1320 Uprated Bypass Valve
Induction
Cat Back Miltek Exhaust
any help much appreciated :)
#2 ·
Hi ya
If you need a remap 1320 is the place to go.
Depending on what cam it is you may not need a remap.
The DME ( engine computer ) is self learning to a degree, you only need a remap to really get the max out of it and correct anything that's out of limit. And if you are running a Big valve heads and big cams and bigger injectors
I would run it on a dyno and get the air fuel ratio checked that's the important bit then work from there.
I am running over 220 with out a map with no problem
Hope this helps
