Torque - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old Jan 13th, 2003, 01:06 PM
Tone's Avatar
Local Time: 03:39 PM
Torque
Okay -what is it? Yeah - we know it's more about acceleration than power, and something about lbs/ft.
The important point is - has the 'S' got it in spades? How much bang do we get for our bucks?
Will conversions to 200bhp add more of the stuff? At what revs is torque at its best?
Anybody have any ideas?
"I get by with a little help from my friends"
Old Jan 13th, 2003, 01:34 PM
Pebble's Avatar
Send a message via AIM to Pebble
Local Time: 10:39 AM
This site is good for learning about engines and other 'stuff'.
How Stuff Works
Here is a link to torque: LINK
Search around that site and it will tell you how horse power and torque are related, Why it's good to have a high end torque and other stuff.
Pebble.
Old Jan 13th, 2003, 02:14 PM
Without getting into another one of *those* threads , torque is measured in pounds-feet. IIRC, one pound-foot is equivalent to a one-pound weight at the end of a foot-long lever. You can test a torque wrench, apparently, by setting up an experiment.
So essentially, a twisting force. Cars are measured by manufacturers at the crankshaft, and by enthusiasts using a dyno, which usually measures how quickly the car can spin up a drum of a known mass. Note that the enthusiast measurement will be lower due to drivetrain losses (friction, etc.)
In the real world, torque translates into the force you feel in the back of the seat.
The S has good torque, I'd say. My seat-of-the-pants impression is that max is around 4k rpm. In the perfect world, I'd like more off-the-line oomph, but it's entertaining nonetheless.
Hope this answers it for you. Howstuffworks is indeed a well-written site if you want more info.
Jeff
Old Jan 13th, 2003, 02:24 PM
Andy@Ross-Tech.com's Avatar
Send a message via AIM to Andy@Ross-Tech.com
If you REALLY want to see one of "those" threads, check out this one:
http://www.mini2.com/forum/showthrea...threadid=21101
'03 MCS every option+Helix/P&D+One-Ball+HAI+Enkei+Falken
The Unofficial MINI 1/4 Mile Dragracing Database
Old Jan 13th, 2003, 10:12 PM
Rich-UK's Avatar
England Male
Here's a good explanation:
Torque gets you going, quick acceleration.
BHP keeps you going at high speed.
or:
Imagine your riding a bicycle, when you start off you push down on the pedal and slowly move away and build up speed as you begin to pedal faster ..... the force you are putting through he pedals is torque!
Then you come to a nice gradual down hil section and you pedal as fast as you can, you get to a stage where you just can't pedal any faster ....... you have reached your maximum power!
Old Jan 14th, 2003, 01:14 AM
Send a message via AIM to BoostingMini
Local Time: 09:39 AM
torque gets you there horse keeps you moving
Old Jan 14th, 2003, 11:56 AM
GTT 280's Avatar
The Power Cube
United Kingdom View GTT 280's Classified Ads
How Stuff Works
That's a really great site !!!
Thanks.
EB.
Old Jan 14th, 2003, 02:46 PM
Tone's Avatar
Tone
Hey Guys - great reads. Thanks.
Old Jan 14th, 2003, 11:00 PM
pcmike's Avatar
United States View pcmike's British Racing Green & Black 1st Gen MINI Cooper S Profile
or:
I'd assume this is why a V8 needs very little revving off the line to get going when compared to a V4? Or am I wrong in making that assumption?
Old Jan 15th, 2003, 12:29 AM
Bilbo Baggins's Avatar
United States Male View Bilbo Baggins's Space Blue & Silver 1st Gen MINI Cooper S Profile
You are sort of correct. It is more of a displacement thing.
Usually, more displacement = more torque = less rpm necessary. If you were to have two engines of equal displacement, one with 4 cyl and the other with 8 cyl, the 4 would rev slower and have more low rpm torque. The 8 would have a wider rpm range and most likely develope more Hp and torque but at a considerably higher rpm. There are really an awful lot of variables that are being delt with here. The state of tune of the engine would make a huge difference.
'06 MCS SB/S R84s(Kumho Ecsta AST, summer), R81s(Nokian Haakapiilatta 2, winter)
'02 MCS DS/W (retired)
Old Jan 15th, 2003, 01:08 AM
Keith's Avatar
Local Time: 02:39 PM
... and then there was this thread... http://www.mini2.com/forum/showthrea...threadid=13238
2007 DS/W MCS LSD, sport suspension, Enkei RPM2 wheels
2002 EB/W MCS Sport package, Rogue intake, Borla exhaust, 15% pulley & Madness sway bar
Old Jan 15th, 2003, 08:30 AM
Tone's Avatar
re: Torque
Think that puts it in a nutshell! Will just add this item from the U.K. press:
"Torque is notoriously difficult to explain, so picture Linford Christie as he's sprinting the 100 metres. In car terms it is primarily the torque that gets him off the blocks and through the first 30 metres or so. Then it's power and torque together for the next 30, and for the final stretch it is pure power that keeps him going to the line."
Looks like it's "torque" that we're all after!
Old Jan 15th, 2003, 12:39 PM
Keith's Avatar
Not wanting to repeat the long thread I mentioned above, here is the short summary:
power is torque * engine RPM. i.e. There is a direct relationship so you don't get one without the other.
In a fixed gear, you get max acceleration at max torque. i.e. If you want lots of acceleration without needing to downshift, it is best to have a lot of torque at the RPM you are driving at.
The higest acceleration will occur in first gear at max torque.
For a particular road speed, you get max acceleration in whatever gear gives you max power. i.e. Fastest runs come from shifting so you drive as close as possible to the power peak.
Given a sufficiently close ratio gear box (so you can use the max power) and equal weight, the car with the highest power will have the best acceleration. That's why power/weight ratio is so important.
Torque Juicysteak First Generation MINI Cooper S 1 Sep 21st, 2006 04:13 PM
torque JTC First Generation MINI Tuning 8 Mar 22nd, 2005 09:29 AM
Torque ???? boothy First Generation MINI Tuning 1 Oct 30th, 2004 12:43 PM
Torque L8 Apex Wheels, Tyres & Brakes 2 Mar 3rd, 2003 11:15 AM
Where did all the torque go? Addicted_to_S First Generation MINI Cooper S 16 Jun 26th, 2002 06:01 PM
