2003 MCS Xenon Ignitor Replacement - MINI Cooper Forum
post #1 of 7 (permalink) Old May 11th, 2014, 05:20 PM Thread Starter
Local Time: 04:38 PM
Hi,
I have a UK May 2003 MCS, the passenger side Xenon dip-beam only comes on intermittently, I have swapped the control units and the bulbs and the fault still remains on the same side, so after a bit of reading, I've concluded it must be the ignitor.
As mine is the pre-facelift version, can anyone on here tell me how to replace the ignitor and where would be best to purchase from......or is the best thing to replace the headlamp unit itself (hope not, as this sounds expensive).
Any help gladly received, thanks
fraggle is offline
post #2 of 7 (permalink) Old May 11th, 2014, 07:10 PM
Local Time: 03:38 PM
Hi ya
Have a look at this link item 7 copy the part no put it in google they are not just for minis.
RealOEM.com * BMW R53 Cooper S Headlight, electronic parts, Xenon light
You should be able to get one from a breakers or ebay
Mini matt or bm spares I would say are your best bet for breakers
You can swap from side to side as you say, if you have swapped the control unit and ignitor and the problem is still there, you will need to start looking at wiring, fuses, fuse box and earths.
Just be careful messing with these lights they are very high voltage
marque is offline
post #3 of 7 (permalink) Old May 11th, 2014, 07:13 PM Thread Starter
Hi, thanks for the information.
Unfortunately mine is the type where the igniter is within the headlamp itself and not part of the connector on the back of the bulb, so the only bits I've been able to swap/check is the bulbs and the control units.
fraggle is offline
post #4 of 7 (permalink) Old May 11th, 2014, 07:28 PM
Hi ya
give me five min I will have a quick look at mine :-)
marque is offline
post #5 of 7 (permalink) Old May 11th, 2014, 07:58 PM
Hi
Just had a quick look at mine there the same as the real oem pic
On mine the loom in the bonner plugs in to the back of the light unit. from that connector it then is routed to the control unit though the headlight unit it's self.
and then to ignitor on the back off the bulb just looks like a black connector plug .
Any chance you can post a pic of the back of the light assy
This may be a usefull link for future ref :-)
http://www.kneb.net/bmw/MINI/mini%20...nsNewstyle.pdf
marque is offline
post #6 of 7 (permalink) Old May 12th, 2014, 06:08 AM Thread Starter
The attached is a picture of the type of ignitor from my Xenons
fraggle is offline
post #7 of 7 (permalink) Old May 12th, 2014, 02:11 PM
Hi ya
There should be a part number on it. From the looks of it a Bosch unit just check some are two pin some are three
bosch xenon ignitor mini | eBay
Hope this helps
marque is offline
2003 MCS Needing New Transmission BroKennArtist General Discussion 0 Apr 28th, 2014 06:52 PM
Fitting upper strut brace to 2003 R53 MCS ihughes First Generation MINI Suspension 8 Apr 3rd, 2014 01:54 PM
2003 MCS Exhaust wanted Duncan27890 First Generation MINI Cooper S 1 Oct 20th, 2013 11:08 PM
