new member, 2003 cooper s help - MINI Cooper Forum
post #1 of 13 (permalink) Old May 19th, 2014, 05:46 PM Thread Starter
Local Time: 01:36 AM
DIY new member, 2003 cooper s help
Hi everyone we just joined as my wife has herself a pink 2003 plate mini cooper s, so I am working on it refurbing the wheels, just serviced it and that sort of stuff.
then today got back to house parked up in the driveway, and a puddle has appeared underneath the front of car where radiator is, seems to be coolant so have jacked up and checked underneath and the radiator plastic end to the left as looking in seems to be pretty wet and the other side of the radiator at the top, there's a patch of the fins seem to be soaking wet also, so my conclusion is the radiator is knackered and a new one is required.
am pretty handy with a spanner and normally do all our own work and servicing etc, but wanted to ask first as new to these cars.
1. are these radiators bad for going or prone to leaking?
2. is there a best place all you guys get your parts in the UK? or just normal factors?
3. what coolant should we buy or is recommended as a full change will have to be done as radiator??
appreciate all and any help in advance.
thanks Grant
wrx fifer is offline
post #2 of 13 (permalink) Old May 19th, 2014, 06:47 PM Thread Starter
Also am I maybe just as well fitting a brand new thermostat at the same time just encase this was the problem and back pressure burst the radiator, for the price of one maybe just as well while its apart?
not checked exactly where they are as of yet but normally always easy enough to get to?
Grant
post #3 of 13 (permalink) Old May 19th, 2014, 11:20 PM
JohnnyC's Avatar
Local Time: 12:36 AM
Quoted: 151 Post(s)
Not sure best place to get a radiator.
IFAIK, leaking radiators aren't common. So I'd get one from BMW depending on the price they'd want.
Might want to consider replacing the coolant expansion tank too, as they ARE prone to leak.
I got my coolant from BMW, but can't remember price, not expensive though.
JohnnyC is offline
post #4 of 13 (permalink) Old May 20th, 2014, 12:08 AM
marque is offline
post #5 of 13 (permalink) Old May 20th, 2014, 12:57 AM Thread Starter
Thanks for the advice folks, I always use comma for coolant changes on the Subaru's, how much is required for one these mini's then around 4-5 litres?
also when you say replace the coolant expansion tank are you meaning just with another oe plastic one, not noticed any leakage around the plastic bottle, however it may burn off dry before its looked at if it is leaking, I will look in to it tomorrow.
post #6 of 13 (permalink) Old May 20th, 2014, 07:52 PM Thread Starter
so would this coolant I found on eBay do the trick? anyone know what the capacity is of the cooling system, i.e. how much do buy and use? don't if the below is a tad dear or a good price?
ok so wont let me post a link either until I have 15 posts sop then its eBay item number 291056904561
post #7 of 13 (permalink) Old May 20th, 2014, 07:52 PM Thread Starter
think I need to get to 15 posts to able to do a few things by the look of it
post #8 of 13 (permalink) Old May 20th, 2014, 07:57 PM Thread Starter
got it down to 21.50 delivered for a 5 litre drum, think that's about as cheap as I will get it for the same stuff
post #9 of 13 (permalink) Old May 20th, 2014, 08:13 PM
Hi ya
Sorry slow reply been up yo my neck in it.
2 lts of concentrate mix 50:50 will give you 4 lts which is plenty and a little left over for top ups as the system settles down
Halfords sell it for 13 for 2lts
http://www.halfords.com/webapp/wcs/s...egoryId_255224
My advice is get a after market coolant tank the oem ones are rubbish and fail.
MINI Cooper S - Coolant Expansion Tank Failure
https://www.promini.com/product-exec/product_id/8249
Hope this helps
marque is offline
post #10 of 13 (permalink) Old May 21st, 2014, 12:46 AM
CCroker's Avatar
Local Time: 06:36 PM
Quoted: 27 Post(s)
United States Male
10 yr. old car, expect more.
Charlie Croker ,BRG 03 Cooper S, SCCA Solo, PDX, Time Trials, RoadRally, and Stella, 011 Oxford Grn Countryman S, with complete Sport Package, stock at present
CCroker is offline
post #11 of 13 (permalink) Old May 21st, 2014, 04:36 PM Thread Starter
yeah I have read a few times now that the plastic header tanks are dodgy, the one in her car does look fine just now anyway, and no signs of leakage anywhere around about it, however I will bear it in mind and keep an eye out for a possible replacement one, normally we clean our engines up and upgrade the hoses and bits and pieces so they look half decent anyway, which normally means replacing random parts we have just not got round to that yet, just starting the bodywork, and refurbed the wheels the other day and done oil and filter and just getting to the engine now really
post #12 of 13 (permalink) Old May 21st, 2014, 04:47 PM Thread Starter
that's perfect I just ordered the 2 Litres of it then and will do a 50/50 mix giving around the 4 litres roughly, thanks for the help, new radiator ordered and should be all done for the weekend as long as the parts arrive tomorrow/ Friday.
Grant
post #13 of 13 (permalink) Old May 21st, 2014, 06:59 PM
No problem glad it helps
marque is offline
Hi from 2003, Cooper S GTT 220 conversion Newbie! GAJA71 Welcome New Members 6 Dec 7th, 2013 08:29 AM
2003 Cooper vs Cooper D minioll MINI Cooper Diesel 5 Feb 1st, 2013 03:41 PM
Changing CD player in 2003 cooper s, which loom?? Lawrence1584 General Discussion 2 Nov 16th, 2012 05:44 PM
