I need help with overheating - MINI Cooper Forum
post #1 of 4 (permalink) Old Jun 7th, 2014, 08:10 PM Thread Starter
Local Time: 11:22 AM
Unhappy I need help with overheating
OK, so my mini cooper started overheating, we have since replaced the thermostat, water pump, fan, radiator and expansion tank to no avail. It starts overheating about 30 min. into my drive, if I turn off the a/c and rev to 2000 rpm the temp gauge goes back down to normal operating temp. Started creeping back up at a red light but once I started moving, gauge went back to normal. Coolant is at perfect level and is boiling in the expansion tank, but the temp gauge is showing normal. We are at our wits end. Need new plugs, but they aren't bad, no smoke from exhaust, no water in oil. Please help!
LoriP is offline
post #2 of 4 (permalink) Old Jun 7th, 2014, 08:29 PM
Hi ya and welcome firstly
What year is your car ? Or what R series if you know
Let us know and we can help :-)
marque is offline
post #3 of 4 (permalink) Old Jun 8th, 2014, 12:26 AM Thread Starter
2006 S convertible, R53
LoriP is offline
post #4 of 4 (permalink) Old Jun 8th, 2014, 02:16 PM
Hi ya
Are the first and second stage cooling fans working ?
To check the second stage cooling fan is working if you turn on your AC while the engine is running the fan should cut in after a little bit to cool the AC rad.
To check the first stage disconnect the black plug for the rad fan there are there wires ( plug located near bonnet latch on chassis leg rh as you look at the car)
Go between the brown wire and one of the red wires you looking for continuity if it ok good do the same with the other red wire if this is ok good.
If one of the wires has no continuity you need to have a look at the fan resistor.
If the fan does not cut in when you turn your AC on look at your fuses and relays in the engine bay fuse box.
If all of this is ok test your water temp sender you can do a resistance verses temp test. your fist stage fan should cut in at 105 deg c coolant temp.
Make shore your supercharger belt is ok you should have one hole visible on the locking tang if not it needs changing as you know if the belt is slipping it will not drive the sc which drives your water pump.
Failing all that you need to pull off your water pump and check the oil in the water pump drive end of the super charger the seals fail in the sc and then the oil is drawn in to the sc and then the gears run dry and wear out and cause cooling problems
Have a look at this link post 304
http://www.northamericanmotoring.com...r-pump-13.html
Hope this helps
marque is offline
Tags: , ,
mini one 1.4 diesel overheating problem. 1.4d mini1.4dhearn First Generation Faults & Fixes 2 Nov 30th, 2014 11:55 AM
Battery warning light, overheating warning light LizzyG Second Generation Faults & Fixes 2 Jan 2nd, 2014 05:30 PM
EBC Redstuff brake pads overheating Rookie Wheels, Tyres & Brakes 6 Oct 12th, 2013 12:24 AM
Loud Fan and Overheating michaelmirra First Generation Faults & Fixes 4 Jan 11th, 2013 03:36 PM
Overheating Nightmare! Bohoflo Second Generation Faults & Fixes 7 Nov 14th, 2012 05:26 PM
