Suspension Question/HELP - MINI Cooper Forum
post #1 of 9 (permalink) Old Jun 14th, 2014, 06:35 PM Thread Starter
Local Time: 07:34 PM
Hi,
I have a 2003 S and being new to the Mini world I have nothing to compare the ride too. This car handles like I would expect a 100k car to handle and that is good, however the ride is so rough my wife went on one ride and said I'm done. When trying to do the shock check by pushing down on the fender, there is no down. I tried opening the trunk lid and sitting on the back tried to produce a bouncing movement with no luck. My 200 pounds could not make it bounce. You feel every bump in the road and some are almost painful. I can't believe the car is supposed to ride like this unless someone make it that way and I have no idea about that. I guess I'm really asking what I can do to change that. I'm pretty sure just changing the shocks won't do it, since there doesn't seem to be any up and down movement. I haven't jacked the car up yet to see if the frame starts up before the tires come off the ground. Thank for any guidance you can provide.
Doug
Rainman 64 is offline
post #2 of 9 (permalink) Old Jun 14th, 2014, 07:03 PM
Caveman's Avatar
Local Time: 03:34 AM
Quoted: 83 Post(s)
MINI changed the oil viscosity and valve structure of shocks effective with May 2003 builds because owners of MCS models (especially those running 17" runflats) complained about the "bone jarring" "teeth rattling" ride.
You can check the build date of your MINI here.
The suspension on 1st Gen MCS models is very stiff regardless of the build date. Many people have switched from runflat to conventional tires to improve the ride. A lot of owners replaced the OEM shocks with Koni FSDs.
Caveman is offline
post #3 of 9 (permalink) Old Jun 14th, 2014, 07:34 PM Thread Starter
Thank you for the information. I'm looking in to the Koni FSDs and most likely will try those. I've read some encouraging info on them.
Doug
post #4 of 9 (permalink) Old Jun 14th, 2014, 09:26 PM
Local Time: 02:34 AM
Quoted: 53 Post(s)
Its cheaper top put an inflatable cushion on the seat like one of those whoopie things and sit on that and leave to car as it is.
The Nun is offline
post #5 of 9 (permalink) Old Jun 15th, 2014, 12:23 AM
Local Time: 01:34 AM
Hi ya
What tires are you running are the RF's ?
What tire pressures are you running ?
marque is offline
post #6 of 9 (permalink) Old Jun 15th, 2014, 03:30 PM Thread Starter
I'm running Hankook Ventus V12 evo 205/45/ZR17 at about 34 psi.
I have a set of Koni FSDs on order and will start there.
post #7 of 9 (permalink) Old Jun 15th, 2014, 03:35 PM
Drop the pressure to 32 might help a little give you a little more flex in the side wall
Sounds like you going in the right direction :-)
marque is offline
post #8 of 9 (permalink) Old Jun 15th, 2014, 04:28 PM Thread Starter
Thanks, I'll give that a try. Hope folks don't misunderstand me, because it is pure pleasure to drive, just want to take a little of the bump out
Thought I would include a picture of my baby.
Doug
post #9 of 9 (permalink) Old Aug 7th, 2014, 02:54 PM Thread Starter
I replaced the original shocks with the Koni FSDs, and "Oh my God" what a difference that made. I would have never thought that shocks would make such a difference. I have it in the body shop now getting a complete new paint job, to include the checker board top. Can hardly wait to get it back. Thank you all for your input.
Front suspension mounts Funsize Min First Generation MINI Suspension 3 Sep 5th, 2015 06:58 AM
Sport Suspension - any real world experiances? F56 Third Generation MINI Cooper S 0 Jun 11th, 2014 07:53 PM
2013 Subaru Impreza STI suspension Rally370 First Generation MINI Suspension 0 May 23rd, 2014 04:29 PM
About Front wheel suspension NiuNiu First Generation MINI Suspension 3 Aug 21st, 2012 09:45 PM
