Brake Line Washer - MINI Cooper Forum
post #1 of 6 (permalink) Old Jun 24th, 2014, 02:33 AM Thread Starter
Local Time: 01:40 PM
Brake Line Washer
Hi
Need help finding a crush washer for the caliper brake line. Took the line off to remove the caliper, and lost one of the washers. Tried a brass one and it leaks. thanks
Doug
Rainman 64 is offline
post #2 of 6 (permalink) Old Jun 24th, 2014, 05:43 AM
Local Time: 08:40 PM
Quoted: 53 Post(s)
I assume its this one your after?
Pt 1165767 Gasket ring, 10X16 4off 0141356 RRPŁ1.79 1.25
You can check here:
www.bmminiparts.com - Diagram View
Or ask your local dealer/service shop?
The Nun is offline
post #3 of 6 (permalink) Old Jun 24th, 2014, 09:07 AM
JohnnyC's Avatar
Quoted: 155 Post(s)
Originally Posted by Rainman 64 View Post
Hi
Doug
You shouldn't be re-using these washers in the first place.
JohnnyC is offline
post #4 of 6 (permalink) Old Jun 24th, 2014, 09:16 AM
Local Time: 07:40 PM
Quoted: 40 Post(s)
Phew, it's a relief to understand what is wanted - I had though the obsessive detailers were now using a dedicated product to wash their brake lines......
Angib is offline
post #5 of 6 (permalink) Old Jun 24th, 2014, 01:23 PM Thread Starter
Thanks for all the replays. Can someone tell me if you have to bleed the front system if you replace a caliper in the back. The question comes from having a hard time getting the pedal to pump up, even there is no air coming out the back bleeders.
Doug
post #6 of 6 (permalink) Old Jun 24th, 2014, 03:15 PM
Doug
Hi ya
Standard practice is to bleed all points if they need it or not,
DO NOT let the system drain or run the brake reservoir empty, or you will end up with air trapped in your abs pump.
If this happens you will need to connect it up to bmw dis software or inpa and put the abs pump into a service mode to be able to remove the air. Or take a trip to mini or a local place that has software to activate the pump.
Never hearts to give the system a good flush with new clean fluid.
Hope this helps
marque is offline
Brake light staying on shazab_rafiq First Generation Faults & Fixes 6 Dec 3rd, 2015 07:06 PM
Bad brake calliper piston MiniDeLux Second Generation Faults & Fixes 2 Jun 18th, 2014 10:21 AM
Mini Cooper brake problem Janie Wheels, Tyres & Brakes 3 Jun 5th, 2014 05:52 PM
Brake line DarkMini28 Wheels, Tyres & Brakes 0 Mar 8th, 2014 07:21 PM
