Rear Noise - MINI Cooper Forum
post #1 of 2 (permalink) Old Jun 25th, 2014, 01:25 AM Thread Starter
Local Time: 10:30 AM
Rear Noise
Hi,
Being new to the Mini Cooper world, I'm probably going to ask a lot of stupid questions, so lets get started. I think I'm pretty good at fixing and building things. I restored my 64 1/2 Mustang from the ground up and converted my 07 Harley Ultra Classic to a trike using a Champion Trike Kit, but this little Mini Cooper has me thinking I have to learn all over again. In my fifty some years I never know you had to rotate the piston to recess it back into the caliper. I broke my c-clamp before I decide to look on line. Then I let the brake fluid reservoir run dry and now I find out I need a BMW software to get the air out of the ABS pump. I don't dare tell my wife this, after an hour of helping me try to bleed the brakes with no luck.
What lead to this was my desire to make the ride a little better. I replace both the front and rear struts with Koni FSD's, which showed that the brake pads were worn out, so one thing lead to another. Now that I have it back together enough to drive it to the shop, I took a short test drive (I made sure the brakes work well enough to stop it) around just to check thing out. What I found was loud knock like sound coming from the rear on both sides. I looked everywhere and can't find anything loose, so I wondering if it's possible to put the rear strut top mount in 180 out, and if so, could that be the cause of the knock. I'm sure the shop can find and fix it, but if it's something I did and can fix first, that would be nice. So please pitch in if it nothing more that to tell me not to talk (type) so much. Thanks
Doug
Rainman 64 is offline
post #2 of 2 (permalink) Old Jun 25th, 2014, 07:23 AM
Local Time: 05:30 PM
Quoted: 53 Post(s)
More often than not a knock coming from the rear can be traced to wear in the rear anti roll bar linkage/bushes? Have you looked at those?
The Nun is offline
Wheel bearing noise from right rear DarkMini28 Wheels, Tyres & Brakes 0 Jun 15th, 2014 05:18 PM
Rear Knocking Noise MiniCrewMax First Generation MINI Cooper S 5 Mar 7th, 2014 11:44 AM
New Mini Owner - Clunk Noise from Rear robt_sf First Generation MINI Cooper S 3 Feb 10th, 2014 11:35 AM
knocking noise from passenger left rear side dessieb123 MINI Cooper Diesel 1 Dec 18th, 2012 07:29 AM
HELP - Rattle/ Knocking Noise from rear passenger side wheel. thegreensnot Second Generation Faults & Fixes 8 Dec 10th, 2012 07:21 AM
