Tyre pressure warning light - MINI Cooper Forum
post #1 of 7 (permalink) Old Jul 15th, 2014, 10:16 AM Thread Starter
Local Time: 03:27 AM
United-Kingdom Tyre pressure warning light
Our R53 Cooper S has the tyre pressure warning light on. It will not reset. There are no punctures and all the pressures are correct. Any idea what could be the cause of this?
steamraiser2 is offline
post #2 of 7 (permalink) Old Jul 15th, 2014, 03:21 PM
Quoted: 40 Post(s)
A duff wheel speed sensor?
Angib is offline
post #3 of 7 (permalink) Old Jul 19th, 2014, 10:10 AM Thread Starter
If it were a wheel sensor would that not cause an ABS fault too?
post #4 of 7 (permalink) Old Jul 21st, 2014, 05:16 PM
beken's Avatar
Local Time: 07:27 PM
Quoted: 3 Post(s)
Canada Male View beken's Black-Eye Purple & Body Color 1st Gen MINI Cooper S Profile
Are you the original owner of the car? Have you reset the Tyre pressure warning before? Just checking, because resetting the light is not as simple as just pressing the reset button.
You have to stop your car. Turn the key to the 1 position, press and hold the reset button until the light blinks (about 5 seconds). Then let go of the button. Start the car and the light should go out after the computer goes through its diagnostics.
05MCS BEP Alta 22mm rear anti-swaybar, Madness CAI, Alta 15%, NGK BRK7EIX, M7 Strut Tower Reinforcement plates, BSH Lower Engine Mount
beken is offline
post #5 of 7 (permalink) Old Jul 22nd, 2014, 07:52 PM Thread Starter
Done all that, the light does not flash there is just a steady light all the time. The plugs on the wheel sensors are not corroded. Its very strange.
post #6 of 7 (permalink) Old Aug 12th, 2014, 03:02 PM
Could it be a faulty switch? If the contacts in the switch are buggered the system wouldn't recognise the reset sequence? Just a thought....
thesingingbush is offline
post #7 of 7 (permalink) Old Aug 12th, 2014, 09:45 PM
Quoted: 12 Post(s)
I suspect your switch is dirty, try pressing repeatedly very fast ....lots, and try again, may sound daft, but can work, they are seldom used for many.
ExclusiveWorkshops is offline
Tyre pressure warning light and failure of electric window JohnHaw First Generation MINI Cooper 3 Jul 7th, 2014 07:12 PM
Tyre pressure light and weird handbrake relationship carbon337 Wheels, Tyres & Brakes 6 May 9th, 2014 07:42 AM
Tyre Warning Light Problem billy.batson General Discussion 2 Apr 26th, 2014 12:02 PM
Pls help re tyre pressure issue (+ warning light)... halesowenmum Wheels, Tyres & Brakes 8 Jan 25th, 2013 09:39 PM
Help me please! Tyre pressure light on - not sure what to do? AmyVee Wheels, Tyres & Brakes 7 Aug 31st, 2012 04:25 PM
