Hello
From the beginning.
Picked up a cooper s with the engine gone, (oil pump failure caused the crank on cylinder 3 pic up) Anyway fitted new engine, clutch and everything else involved. Car ran mint for 2 months. Wife got in it one day and both the DSC and run flat light on. Checked it on snap on diagnostic and fault code 005E38 rotation rate sensor. Ran the car with live data and all wheels showing a wheel speed that is pretty balanced.
Bit the bullet and put in BMW for a diagnostic, apparently it has water ingress in the BC1 and fuse 5 no power. Also same code for the rotation rate sensor.
Have looked at the BC1 wiring, nothing looks like it runs through the DSC unit. Also no sign of water damage just a slightly damp carpet. Have re calibrated the steering angle sensor and had alignment checked.
Spoke with a mini specialist today who informs me that fuse 5 is not used on my model and will have no power. Is this correct ?
Anybody have any ideas of what to check next ?
Wiring to DSC unit not been damaged on the bracket!
What could cause the water in the footwell ? Non sunroof model.
Also noticed water in the boot ? Rear lights ???
Apologies for all the questions ! Any help greatly appreciated.
Car will be broken for spares if I can't get it sorted as nobody wants to buy it !
From the beginning.
