| First Generation MINI Cooper S MINI Cooper S 2002 - 2006 |
| If the objective is improved peformance, you can certainly do it as well or better and much cheaper than JCW. As best I can tell, the only real JCW upside is that it allows you to keep your warranty. If you do it yourself, that MAY be an issue depending on your dealer and the problem: US law says that unless a problem can be shown to have been caused by a mod; they cannot deny you warranty coverage. Anyway, if you replace the intake, the pulley, and upgrade the exhaust; you're close to 200 HP. Add an ECU upgrade and you're over that! '02 EB/W MCS w/Sport pkg, Rogue intake, Helix 15% pulley, Magnecor wires, Bosch platinums, Magnaflow exhaust, Exel white wheels. |
| The pros and cons of the JCW kit as opposed to other kits (hartge, GGR etc.) have already been very well discussed in many threads. I would personally think it was the "safer" way to go if you don't mind spending the dosh, as the uprated head and supercharger will last longer theoretically than the stock items operating at a similar HP, as they are built for the job and have been tested extensively. May also give you a sounder base for tweaking the engine a little further at a later date if you feel like it. |
| JCW seat fitting- tilt connector fitment? | eddycooper | First Generation Works | 1 | Jun 20th, 2007 09:03 AM |
| fitment of New JCW steering wheel | grant watson | First Generation Interior & Ice | 7 | Jun 6th, 2007 09:01 AM |
| Induction Kit Fitment | jango-fett | First Generation MINI Tuning | 4 | Apr 6th, 2007 08:44 AM |
| JCW 200hp modified cars wanting to update to JCW 210hp kit. | setox | First Generation MINI Tuning | 22 | Jan 27th, 2005 10:41 PM |
| 2 thumbs up for Thule MINI fitment kit!! | liminiac | First Generation MINI Exterior | 3 | Jul 24th, 2004 03:59 AM |
