Parking light / side light issue - MINI Cooper Forum
post #1 of 10 (permalink) Old Jan 7th, 2017, 07:50 PM Thread Starter
Mini Cooper S Newbie
Local Time: 07:57 AM
Quoted: 4 Post(s)
England
Hi all,
Could really do with some swift advice please as worried battery will flatten quickly and this is my daily drive.
Went out to the car tonight and noticed that both small side lights are on on the car irrespective of key in ignition or not ... lock the car and walk away ... still on ... it's a new thing as wasn't there when first purchased the car but clearly despite it only being what looks like parking light power but could be side light I guess ... (as both are on when car locked and key in my pocket)
anyone else's had this and any ideas how to reset this ?
Cheers in advance ...
runner25 is offline
post #2 of 10 (permalink) Old Jan 7th, 2017, 08:01 PM
Quoted: 707 Post(s)
Where in the car are the lights located?
SeanC is offline
post #3 of 10 (permalink) Old Jan 7th, 2017, 09:03 PM Thread Starter
Quoted: 4 Post(s)
England
So we are taking about (possibly) the led side lights ... the lights between the main xenon lights and the fog lights ... effectively the blinkers orange lights and the small white lights ... it's the white lights / possibly led's that are remaining on ( just the white not the orange bit)
runner25 is offline
post #4 of 10 (permalink) Old Jan 7th, 2017, 09:35 PM
Quoted: 707 Post(s)
The lights on the bumper then?
Sent from my SM-J510FN using Tapatalk
SeanC is offline
post #5 of 10 (permalink) Old Jan 8th, 2017, 08:30 AM Thread Starter
Quoted: 4 Post(s)
England
Yes. Just the White elements (looks like 2 tiny bulbs) stay lit ...
runner25 is offline
post #6 of 10 (permalink) Old Jan 8th, 2017, 11:50 AM
Quoted: 707 Post(s)
Have you checked the bulbs? They should be W5W and some folk change these for led's and through time they begin to fail so stay lit. Also the battery could be a factor so that may be worth having checked too
SeanC is offline
post #7 of 10 (permalink) Old Jan 8th, 2017, 01:33 PM Thread Starter
Quoted: 4 Post(s)
England
The battery is a new one Sean ... well month old so shouldn't be an issue but bulbs look like very small bulbs rather than LEDs ? Is it normal to light like this then ? I say normal I mean a mini feature ? N
runner25 is offline
post #8 of 10 (permalink) Old Jan 8th, 2017, 02:31 PM
Quoted: 707 Post(s)
The bulbs are w5w's so whip them out and check them. It may be worth sticking a new pair in to see if this helps as they are cheap enough. If they still illuminate with new bulbs then check the terminals and work back as it could be an earthing issue.
SeanC is offline
post #9 of 10 (permalink) Old Jan 11th, 2017, 04:16 PM
Quoted: 28 Post(s)
I want to put LEDs in my front side lights as they are a horrible dim yellow. I bought some on eBay a while ago but they are too big to go in. There's naff all space in there. However I took a picture recently of the standard W5W beside an LED that WILL fit. Might help as to which your car has.
Name:	LED Bulb Comparison from Steve Small 01.jpg
ID:	209898   Click image for larger version
Name:	LED Bulb Comparison from Steve Small 02.jpg
NigelK is offline
post #10 of 10 (permalink) Old Jan 11th, 2017, 09:11 PM
Quoted: 707 Post(s)
I managed to get led's to fit in to my side lights Nigel. Keep looking on the bay as there are smaller ones and look for ones with just a couple of led's in them as I found any more than 4 were over powering
SeanC is offline
Problem with rear light light and right side indicator Jamie7755 Second Generation MINI Exterior 0 Nov 17th, 2015 11:34 PM
Very annoying brake warning light issue! Kerinsey Maintenance & MINI Care 0 Feb 23rd, 2014 03:10 PM
Mini headlight / side light issue(i think) help caball Second Generation Faults & Fixes 1 Jan 25th, 2014 05:06 PM
changed my side light bulbs romiloned First Generation MINI Exterior 0 Nov 9th, 2012 08:09 PM
Parking light issue Albatros1 First Generation Faults & Fixes 2 Aug 16th, 2012 01:59 PM
