Sensitive oil sensor? - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old Sep 8th, 2003, 05:08 PM
Local Time: 08:59 AM
United States View Aggie_Devil's British Racing Green & White 1st Gen MINI Cooper S Profile
Question Sensitive oil sensor?
I think I might have a very sensitive oil level sensor in the Cooper S. When the car has been running for about 30 minutes, the oil light will come on momentarily when accelerating. I can't make it happen though.
I checked the level and it is right in the middle of the stick.
Has anyone had this problem? Any suggestions. I am taking it to the dealer this week.
Thanks,
Jason & Lori
Old Sep 8th, 2003, 05:47 PM
chiph's Avatar
Spectator
Local Time: 10:59 AM
United States View chiph's Electric Blue & White 1st Gen MINI Cooper S Profile
Have your dealer check the oil pressure with a gauge -- you could have a problem with the oil pump.
Chip H.
ex-MINI Cooper S owner and all around good-guy
Old Sep 8th, 2003, 08:55 PM
swamos's Avatar
MINI Traitor
Send a message via Skype™ to swamos
Local Time: 12:59 AM
Australia View swamos's Electric Blue & White 1st Gen MINI Cooper S Profile
Get it done quickly. You don't want the pump stopping or not delivering enough pressure
Old Sep 9th, 2003, 08:13 PM
Local Time: 04:59 PM
Netherlands View King Q's Dark Silver & Black 1st Gen MINI Cooper S Profile
What colour has the oil-light? If it's red then it's probably the sensor that's bad. I had the same and if you touch the sensor you can see the light come on. Your dealer can fix this.
Brake Light Sensor & Sensor replacement help needed wrxtomini First Generation Faults & Fixes 7 Apr 20th, 2006 07:55 AM
sensor oil presssure tili67 First Generation MINI Cooper 1 Mar 14th, 2006 01:12 PM
OIL sensor from the motor DeK First Generation MINI Cooper S 8 Nov 15th, 2004 01:33 PM
Oxygen Sensor or Coolant sensor???? maximusrp First Generation MINI Tuning 5 May 30th, 2004 06:33 PM
Changing Oil and the Maintenance Sensor GizzmoGeek First Generation MINI Tuning 7 Apr 29th, 2002 03:16 PM
