| First Generation MINI Cooper S MINI Cooper S 2002 - 2006 |
| Pappillon -- Don't beat yourself up about this. After owning and racing sports cars over the last thrity-some odd years, I always considered myself fairly adept at shifting. However, I do admit to having to make some adjustment to the MCS gearbox prior to it being run-in. After 3,000 miles, the gearbox has become much smoother, and so have I. No doubt there is a human element to this equation, but you will soon find the "groove". You now have an official excuse to drive the MINI at all times of the day and night in order to "practice". "The problem with using quotes from internet sources is that you can never be sure they are authentic." - Abraham Lincoln |
| Hi, When your passengers head lurches forward as you upchange, it's because you've suddenly stopped accelerating as you've put in the clutch- it's literally their head braking! To avoid this happening, make sure that when you clutch in you're neither accelerating or decelerating, just on a static throttle position. Get to a set speed, clutch, change, clutch out (whilst 'biting' the clutch upwards, try to match engine speed with road speed to avoid any jolt) then add throttle to accelerate further. This way you are not interrupting any acceleration whilst changing gear. |
| Confused I was taught (and thought everyone did this) that when changin up the gears you gently lift off the accelerator whilst simultaneously pushing the clutch in. Then gently release the clutch and apply accelerator. |
| I thought this also. But then again, I'm having the same issues with my MCS! (have had it about 2 weeks now) '04 EB/W MCS, AC, H/K stereo, Lapis/Black leather...arrived Dec. 26!! |
| For upshifts, as was said earlier, it's just the passenger's momentum going foreward after acceleration. There's not really anything you can do about this except accelerate slower. The only real thing you can do is make sure th clutch engagement is clean without jerks. For downshifts, double-clutch! It's not very hard to learn and it saves the syncros. It's nice to know how to do when you need to get down into a lower gear to pass too. Heal and toeing is very hard in the MINI as the accelerator and brake petals are not close enough to each other. When you upshift, you are supposed to simultaneously lift up on the throttle and push in the clutch. What he's saying is to try and speed up/slow down your shift so your engine speed will match the vehicle speed when going into the next gear. It's what double clutching does, but then you rev the engine to match the gear down. |
| Gear Change Noise. | Judge Cooper S | First Generation Faults & Fixes | 4 | Nov 21st, 2005 09:54 PM |
| When to change gear?? | wee rocket | General Discussion | 17 | Jul 21st, 2005 03:02 PM |
| Change gear when? | C12OGN | First Generation MINI One | 4 | Jan 30th, 2005 10:09 AM |
| How do i change the gear nob? | ccVIPERcc | First Generation Interior & Ice | 2 | Apr 5th, 2004 09:45 AM |
| Jerky gear change from 2nd gear | stellablade | First Generation Faults & Fixes | 7 | Sep 30th, 2002 12:58 AM |
