| First Generation MINI Cooper S MINI Cooper S 2002 - 2006 |
| I don't think any of the tires you listed in 16" or 17" are run flats, which might also be a consideration. If run flats are not a consideration and you have 16" wheels, you'd want to replace the 195/55's with 205/50's, for which the TireRack offers 15 summer and 5 all-season choices, all with speed rating of 149mph or higher. |
| Thanks MINIAC Beat me to the punch! There's PLENTY available, don't worry. Just to make you feel more comfortable, here's the stats: If you run a 205/50R16, your overall diameter is .3 lower. Your speedometer will read 1.5% too fast, meaning, when your speedo says 60mph, you're doing 59.1mph. Now, there's also a special on the BFG g-force KDW in the 215/50R16. If you run a 215/50R16, your overall diameter is .1 taller. Your speedometer will read .1% too slow, meaning, when your speedo says 60mph, well, you're still doing 60mph. I'm not even going to get into the 17's, but here's the best tire size calculator I've ever seen: http://www.miata.net/garage/tirecalc.html Have fun, and don't stay up too late - 2005 G Stock '05 MINI or it's back to a Miata in C Stock - 2004 G Stock 2nd place Pro Solo, 9th Place Solo II - 2003 STX 5th place Pro Solo, 6th Place Solo II - 2002 H Stock Pro Solo National Champion Last edited by Garfield; Mar 14th, 2002 at 08:09 PM. |
| MINIAC & Garfield, thanks for weighing in! I'll try not to be up too late with the tire size calculator .I was hoping somebody had some info on other sizes that would work and as usual, the forum didn't disapoint me! The run flat issue is another good point. Thanks guys! |
| Wheel and tire choices.. Please advise.. | aquaanox | Wheels, Tyres & Brakes | 3 | May 23rd, 2005 03:23 AM |
| Wheel and Tire Size Issue | CooperSAZ | Wheels, Tyres & Brakes | 6 | Oct 26th, 2004 03:39 AM |
| Wheel/Tire Size for 220+ HP? | TonyB | Wheels, Tyres & Brakes | 24 | May 7th, 2003 10:58 AM |
| Comfort+Fun-Ss+,seats,wheel/tire choices | smith | General Discussion | 4 | Apr 17th, 2002 12:18 PM |
| Tire Availability | MINIAC | Wheels, Tyres & Brakes | 1 | Jun 18th, 2001 08:28 AM |
