Recommended engine oil grade for tropical weather? - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old Sep 15th, 2004, 03:06 AM
roadsleeper's Avatar
Send a message via ICQ to roadsleeper Send a message via AIM to roadsleeper
Local Time: 10:11 PM
Singapore View roadsleeper's Pepper White & Black 1st Gen MINI Cooper S Profile
Hi all,
Am expecting to be running a MCS within a few weeks and was wondering whether anyone had any suggestions as to the best engine oil grade for tropical (read mean temperature of 27 degrees C / 80 degrees F) weather.
I used to run Valvoline Synpower Synthetic in my Mk. IV Golf VR6 in the States, with a summer weight of 10w30, so I am planning to use the same oil for my incoming MCS.
However, I'm now stuck with the problem of living in the jungles of Singapore, so I'm wondering what grade to use. Instinct tells me 20w50 would suit me fine, any other suggestions?
Old Sep 16th, 2004, 12:22 AM
Local Time: 04:11 AM
United States View JCIP's Liquid Yellow & Body Color 1st Gen MINI Cooper S Profile
United-States
My insticts suggested the 5-50, but I have been running the 5-30 with no problems. I am in Hawaii, and ambient air temps can range from 50 to 90 degrees F, depending on altitude. I regularly travel from sea level to 2500+ feet. The 5-30 is doing fine. I like the 5w lower to be sure that the SuperCharger and everything has a good initial oil supply at start-up.
Old Sep 17th, 2004, 10:15 AM
Interesting reply, especially given that you're encountering somewhat similar climatic conditions as I am. Did you go with such a light weight because you thought it would expedite lubrication of moving parts?
I was using this chart (courtesy of www.chris-longhurst.com) as reference:
Anyone else want to share their experiences?
Old Sep 17th, 2004, 06:41 PM
United-States
Yes Roadsleeper. I definately like the 5w so that there is a lightweight component to the oil on start-up and cool conditions. I change my oil @ 3000 miles anyway, so I don't worry about it breaking down. On some of my other cars I do run 10-50 or 20-50, but these are bigger cars with different engines. I don't think those motors have the tolerances of the Mini engine, and perhaps don't need the thinner oil component for good lubrication.
Old Sep 17th, 2004, 07:34 PM
GordonD's Avatar
Local Time: 10:11 AM
Scotland View GordonD's Dark Silver & White 1st Gen MINI Cooper S Profile
We get big temperature range in Torornto -30C to +30C and there have been no reported problems by anyone using the factory recommended 5W30 synthetic all year round
aka KWKSLVR
Member:
Southern Ontario MINI Club
BMW Club of Canada - Trillium Chapter
Old Sep 23rd, 2004, 09:31 AM
Cheers for the information guys, much appreciated. Looks like I'll most likely go with the 5w30 once the break in is over.
Which grade of oil? elvish_dan Second Generation MINI Cooper 4 Sep 24th, 2007 06:07 PM
Oil Grade???????? stuartMCS Maintenance & MINI Care 1 Jul 3rd, 2006 07:37 PM
HELP! - What grade of gearbox oil? dsakko Maintenance & MINI Care 0 Oct 8th, 2004 09:42 PM
Thank You To Whoever Recommended Peanut Oil trico First Generation MINI Exterior 1 Jan 11th, 2004 09:02 PM
Oil Grade TLC RJGCooperS Maintenance & MINI Care 0 Jun 15th, 2002 12:20 PM
