| First Generation MINI Cooper S MINI Cooper S 2002 - 2006 |
| I have an '04 (Jan build) w/ ~20k miles that while I haven't seen this exact behavior, I have noticed it's taking longer to crank over in the AM...longer than the middle of the winter w/ the extreme cold. Takes 2-3 secs to get it to turn. This also occurs if I take it out for lunch (5 hrs after arriving @ work and it sits). I forgot to mention this last week when I was in for svc (windshield), but will when I take it in in a few months for its normal svc. I'm at v39.1 and I asked about the v41, but was told by the Service Advisor that my car didn't need it. |
| This is a famous (infamous) problem with MINIs in USA - particular areas of the country are most affected at the start / end of "winter" - general opinion is that the chemical mix in the gasoline changes and confuses the engine computer. You could try to get your dealership to wipe the learned engine parameters - then the car should run OK through the summer until the gas mix changes again in (approx)November. The software is better than it used to be - GBMINI#2 used to stall and have to be restarted; now GBMINI#3 just runs very rough and tries to stall for a few seconds. Gary (head tech) at MINI Peabody suggested a lower octane gasoline (easier to ignite) but I have not tried that yet. |
| Gary & Chris told me the same thing (when I bought my MCS in October), I've been using lower octane the last couple of times I filled up because the car was basically stalling on the 1st cold start of the day (it's been going in the 20s overnight here in Maine ). It actually helps a lot. However, I definitely would like to get my ECU reset on my next service so that I can go back to higher octane. |
| This has been happening to me too. not as quick, occasionally after 15 seconds. I remember reading something on these boards about starting your car then blipping the RPMs a bit, then taking off. Alot of people were saying it was bad to leave the car idling at a cold start. "Those Griffin boys better grow some wings, or start flapin their arms." |
| DO NOT run lower than premium octane in a MCS! Not only will you lower your MPG, make the computer pull timing to save your engine from detonation - it doesn't fix the cold start problem! It's a simple by product of the current software. There's nothing we can do right now to 'fix' it, it's all in the software. Flashing helped greatly on mine, other software upgrades have had good luck as well. As for stock software cars, we can only hope MINI cures it in the next version, and you'll have to get your car updated. Last edited by Humourl3ss; May 23rd, 2005 at 11:30 AM. |
| I have this problem also with my '04 MCS. I agree with one of the posters above. It most often happens with seasonal changes ie: the fuel reformulations they do. I always run 93 octane of higher. The problem also occurs after a session of hard driving. After a "spirited" commute home at night, I pull into my driveway, apply the parking brake and the revs drop well below normal idle sometimes almost to the verge of stalling. even if I gun the throttle a bit it still drops. Next morning it's usually fine. |
| this works for me - try it , you'll like it! On another board this question has gotten a lot of airplay.The suggestion was made to do the following at start up: turn the key to the position just before start up, if you look at the speedo, you will notice that after a few seconds, the DSC triangle at the bottom goes out.This is an indication that the fuel pump has successfully delivered gas to the motor, as it seems that there is some kind of flow back to the tank during longer periods of innactivity.Once the light goes out , proceed to cranking the engine with no accellerator .This worked for me and I think the real culprit (at least here in the Northeast) is partly due to the "summer" gas.I do let the car idle for a minute or so before taking off, and yes I sometimes get a stumble innitially, but it goes right away.Good luck. Jock |
| I, too, have this problem and brought my MINI in last week. Though they found nothing wrong, the MINI techs (Keeler MINI) suggested that every 6 or 7 fill ups to use a lower octane fuel. I'm going to give it a try. Oddly enough, my MCS didn't do this at all during the winter, but has started to struggle during this damp spring weather. 2005 MCS, BRG/W, Premium & Cold Weather packages... |
| I picked up my 05 MCS in Feb. I have been having the same problem but only in the spring weather. i havent used lower than 93 octaine either. I am having a weird whinnig noise tho when my car sits for a while when its running. i'll be at a red light then it starts like a buzz/whine then slowly quiets and disappears. anyone heard of it??? |
| Won't start.......................NOT cold start issue | Rwatts4mini | First Generation Faults & Fixes | 2 | Nov 5th, 2011 01:16 PM |
| Cold Start | Wade | First Generation Faults & Fixes | 40 | Sep 24th, 2007 06:32 AM |
| My cold start issue is now a warm start issue | FrenchCori | First Generation Faults & Fixes | 0 | Mar 31st, 2006 10:39 PM |
| Cold-start problem? | Robert In Denver | First Generation Faults & Fixes | 9 | Jul 8th, 2003 06:16 AM |
| Will not start period....NOT Cold Start Issue | Silly | First Generation Faults & Fixes | 31 | Aug 5th, 2002 02:35 PM |
