Bonnet scoop - MINI Cooper Forum - MINI2 Mini Cooper Forums
LinkBack Thread Tools Rating: Thread Rating: 6 votes, 5.00 average.
Old May 30th, 2005, 12:11 PM
Joyrider's Avatar
Local Time: 04:45 PM
United Kingdom View Joyrider's Classified Ads
Bonnet scoop
Just a quick stupid question, should the standard MCS bonnet scoop have a grill behind it or should it just be totally open? Just wondering if mine is missing the grill part as I'm sure I've seen them with one...
Old May 30th, 2005, 12:54 PM
Mini owner wannabe
Local Time: 05:45 PM
Netherlands
Question
Since I'm not owning a MCS yet I might not be the best source for your answer but I'll share my thoughts with you anyway. As far as I remember the bonnet scoop doesn't come with a grill, some people have installed aftermarkt grills to prevent debry from comming in. Might have to check with your dealer.
Yoshi
Old May 30th, 2005, 12:56 PM
fj0's Avatar
fj0
Sugardaddy
Send a message via AIM to fj0 Send a message via MSN to fj0
Sweden View fj0's Solid Black & Body Color 1st Gen MINI Cooper S Profile
I don't recall seeing one on mine, but I think there are aftermarket ones.
Cheers, Mario
MCS '03 JB/B - Black, LOUD and loow!
Old May 30th, 2005, 12:59 PM
Joyrider's Avatar
That's okay then, just thought I'd better check....thanks!
Old May 30th, 2005, 02:00 PM
Pamlico's Avatar
Dead Man's Curve? Feh.
Send a message via AIM to Pamlico
Local Time: 11:45 AM
United States Male View Pamlico's British Racing Green & Black 1st Gen MINI Cooper S Profile
The scoop is not outfitted with a screen from the factory. There are a couple of aftermarket suppliers. There are also instructions for making your own floating around as well.
Old May 30th, 2005, 06:01 PM
beken's Avatar
Send a message via ICQ to beken Send a message via MSN to beken Send a message via Yahoo to beken Send a message via Skype™ to beken
Local Time: 07:45 AM
Canada Male View beken's Black-Eye Purple & Body Color 1st Gen MINI Cooper S Profile
This has been discussed elsewhere in Mini2.
Found elsewhere....
http://www.tech-esq.com/MINI/how_to_...oop_grille.htm
I'm going to make one myself too.
Old May 31st, 2005, 05:21 PM
holdenontoit's Avatar
lost in the ozone again
Local Time: 10:45 AM
United States Male View holdenontoit's Classified Ads
food for thought:
the scoop is there to provide unimpeded air to your interCOOLER.this in an effort to cool the superheated supercharged air going into your injectors.ANY screen introduced will cut down on the air flow to your intercooler and I will grant you , will cut down on the myriad bugs and small rocks that seem to make thier way in there.It's a trade off, but I err on the side of air flow.
Old May 31st, 2005, 07:11 PM
beken's Avatar
Quote: Originally Posted by holdenontoit
food for thought:
I agree. But for "normal" driving, I'm not sure if the reduced airflow would be significant enough to impede driveability of our Cooper S'.
Others have done it and it doesn't sound like the reduced airflow causes a problem. Some of the screens look open enough that only big objects are blocked from getting in. For those with lots of windshield cracks due to rocks throw up from trucks in front of them, a screen would be necessary protection. Small pebbles would still probably find their way in through the scoop. If your commute means lots of highway driving, I would recommend adding a screen. But if most of your driving is in the city, it might not be necessary. Make sure the screen isn't too fine as it would restrict air getting in. Just an opinion.
Old Jun 2nd, 2005, 06:15 AM
tavis1's Avatar
a.k.a Handsome Rob
Local Time: 08:45 AM
United States Male View tavis1's Chili Red & White 1st Gen MINI Cooper S Profile
food for thought:
I have the screen and noticed no difference in performance what so ever. I live where there is a lot of bugs and it helps big time to keep them out. I just take a toothbrush to clean it and I am done. It is a major pain to clean the inter-cooler properly.
"There can be only one"
Old Jun 2nd, 2005, 06:32 PM
beken's Avatar
Hey Tavis1, what is your bonnet scoop screen made out of? I went to my local Home Depot last night and the only roof gutter material they had was made of plastic. So I decided to look around.
Just thought I would consider my options...
THanks.
Old Jun 3rd, 2005, 12:03 AM
Rich'sFroggy's Avatar
THanks.
Home Despot sucks donky! Go to a good old timey, family operated local hardware store. the more old and decrepit the better. I bet they will have the metal kind. Thats what I'm gonna do.
Old Jun 7th, 2005, 06:10 AM
tavis1's Avatar
a.k.a Handsome Rob
THanks.
its small expanded metal. I got it from www.cooperparts.com . it was like $18 dollars or something like that. it gets sandwiched between the painted outside scoop and the black inside scoop part. I have expanded metal on the scoop and the the lower radiator grill and they remain clean. However where I don't have it, on the main grill part, there tons of bugs packed into that part of the radiator. Definitely something that does form and function.
Tavis1
Old Jun 9th, 2005, 11:20 PM
Mine not come out so good. Crooked. Could not get the heavy gauge wire. And I don't like that the holes are vertical diamonds. I need to do over.
Old Jun 9th, 2005, 11:31 PM
Pamlico's Avatar
It looks like you've got at least as much material as holes which would significantly cut down on the amount of available air passing to the intercooler. You might want to look for a heavier gauge wire with a larger mesh.
  #15 (permalink)
Old Jun 10th, 2005, 01:47 AM
The thought has crossed my mind. It's a little deceptive, the pic. The screen is composed of flat strands of wire that are angled. So when you look at it head on you see a lot of material, but I suspect the air flow through easily, only being slightly deflected when passing through the wire, but still entering the scoop. I could be wrong. I'm no aerodynamicist......But I'm gonna change it anyways.
Bonnet Scoop... Option? BlownMini First Generation MINI Exterior 25 Feb 5th, 2008 12:21 PM
Bonnet Scoop JG02JSG Second Generation MINI Exterior 1 Dec 13th, 2006 04:16 PM
Bonnet Scoop pubert First Generation MINI Exterior 9 Jul 31st, 2006 11:53 PM
Cooper S Bonnet Scoop MarkWMC First Generation MINI Exterior 26 Jan 16th, 2006 01:07 PM
bonnet scoop new skool First Generation MINI Exterior 6 Oct 3rd, 2004 12:49 PM
