| First Generation MINI Cooper S MINI Cooper S 2002 - 2006 |
| The thread on 2nd Gear Grunt - Initially very flat prompted me to do an Excel spreadsheet on Cooper S speeds at various RPM in each gear, which I've attached here (I hope!) in case anyone’s interested. I used the Cooper S gear ratios off the MINI2 data section, and I based the sheet on the premise that the maximum speed of 135 MPH would be achieved at redline RPM of 6750 in Vth gear. This may be slightly incorrect, if so please let me know, but I don't think it will be far off. If you prefer, you can enter any known combination of road speed, RPM and gear you like in the cells so labelled (C11, C12 and C13), and everything else is then calculated from the gear ratios. Initially I tried using 95MPH, 4000RPM and VI gear (an approximate combination I happen to know only too well as Stonk is still running-in), but that gave a theoretical redline Vth gear speed of only 130.9 MPH, which didn't seem right. I figured that the EMS wouldn't permit a 135MPH maximum over redline, hence I used the settings above. (Note: I've protected the rest of the sheet, so you can't inadvertently change anything else, but the password to unprotect it is not hard to deduce!) |
| It looks like my guess back in October last year was pretty close. In this thread I estimated the speed at 6500rpm in each gear based on the published rattions and tire diameters. I used 6500 because the real red line was not known at that time. http://www.mini2.com/forum/showthrea...&threadid=1825 2007 DS/W MCS LSD, sport suspension, Enkei RPM2 wheels 2002 EB/W MCS Sport package, Rogue intake, Borla exhaust, 15% pulley & Madness sway bar |
| Not according to the FAQ: What should be considered in choosing a wheel and tire package? , which shows the following diameters for the standard packages: I recalculated the spreadsheet, using just the gear ratios and the diameter of the MCS standard 16" wheel and tire package, see attachment. It was pleasing to find it quite similar to what I had calculated in the earlier spreadsheet, based on the prediction that maximum speed of 135 MPH would come in Vth close to the 6750 RPM redline. You can enter other diameters if you so wish. Maybe VI was geared to give reasonably good fuel economy for motorway driving; V was geared to give the highest possible maximum speed (based on the torque curve characteristics); and IV, III, II and I were geared to have reasonably close ratios, given the requirements for VI and V, which in turn meant that 1 had to be fairly tall ? |
| Yopu should not need to make assumptions about red line in 5th being max speed. The gear ratios are known as well as the tire diameters so the speed in each gear can be calculated. 2007 DS/W MCS LSD, sport suspension, Enkei RPM2 wheels 2002 EB/W MCS Sport package, Rogue intake, Borla exhaust, 15% pulley & Madness sway bar |
| There are tables on top speed in gears posted in the FAQ on transmission choices. ![]() |
| Addicted, Thank's for pointing out my error on the tire diamater, bad memory on my part, this would result in 5th topping out at another 1 mph. Keith has made the point that, I guess, I only eluded to, that top speed is probably in 6th gear and provided a link to his response to my earlier post as "bluebaru", I forgot my password for that name and just changed user names. (see above memory statement) |
| Indeed Keith, you are right, which is why I posted the revised spreadsheet "mph & rpm2 - cooper s.zip", which makes no such assumptions and is based purely on gear ratios and tyre diameters. But then I looked at your postings back in October where you refer to the RPM per mile value of 855 (for 205/45-17), which I agree is a better basis for calculation. So I made what I hope will be the final version of the spreadsheet "mph & rpm3 - cooper s.zip", in which you can enter whatever RPM/mile value you like. Interestingly the Firestone 195/55-16 shows a very similar RPM per mile value at www.tirerack.com of 854, and I used this value originally as it's the size I have on my S. I notice that most of the Tirerack RPM/mile values are about 3% greater than what you'd calculate from the overall tyre diameter in inches (63360/[Pi*D]), presumably due to deformation by the weight of the car. Perhaps different wheel/tyre combos differ in the degree of deformation, which changes the story on which give the greatest acceleration or maximum speed? Thanks for setting me straight on this. |
| 5th & 6th Gear over 5k rpm? | Cooooooperslad | First Generation MINI Tuning | 34 | May 1st, 2007 07:50 PM |
| Gearbox Vibrations in 3rd gear @ 4'000 RPM | le_knut | First Generation Faults & Fixes | 5 | Sep 26th, 2005 04:09 PM |
| (Draft) How-To: Get more info. from your MINI's cpu (Digital RPM, Speed, Volts etc) | Paul | First Generation Interior & Ice | 39 | Sep 22nd, 2003 04:42 PM |
| New DIY:How to show RPM, Fuel Levels, Speed and more on your Odometer Digital Display | Paul | General Discussion | 8 | Sep 20th, 2003 01:22 PM |
| Cooper MPG(CVT?)and(5 speed) and RPM levels | MiNi | First Generation MINI Cooper | 29 | Aug 30th, 2002 07:26 AM |
