Over the weekend I decided it was time i changed the reverse light switch as my reverse lamp was deciding it didnt want to light up sometimes
So anyways, changed the switch as I should with no problems, and I also disconnected the battery to be on the safe side while I carried out the work.
When I had put everything back together and reconnected the battery, started the engine and everything was fine, great
But then as I looked....... the outside temp reading on the rev counter and the reading on my climate control knob had changed and now read in deg C rather than deg F
This is not a problem, i mich prefer it. But i read somewhere that they couldnt be changed unless I had the on board computer?
Dont know if this makes a difference but by accident, while I disconnected the battery I left the ignition on position 1. So when I came to connect up the battery I got a spark when i touched the positive cable on the terminal. This is when I realised I had left the ignition on so i turned it off and connected the battery back up.
Any ideas? As I say its not a problem, infact I like it, just puzzled
