| First Generation MINI Cooper MINI Cooper from 2001 - 2006 |
| Hi there, If you have a notchiness, generally at 10 o'clock and 2 o'clock, then it is probably a new upper steering column required. Try doing a search in the forums plently of people have had them replaced including me. Free under warranty or otherwise in the mid hundreds i believe. Hope this helps although may not be the news you were after! |
| I have this same problem that has just started to arise it seems to be more noticable when the car is cold from start but i may just notice it more when first pulling off. JAMSKI did you ever find out what was causing this problme for you? Thanks. |
| Tags: power, steering |
| Power steering Pump replaced-Steering slightly off centre | Rooster | First Generation Faults & Fixes | 4 | Apr 26th, 2010 01:35 PM |
| Tight steering feeling - how to get it back | camini | First Generation Faults & Fixes | 3 | Sep 14th, 2006 07:10 PM |
| Power Steering Feeling Light.... | irnbru | First Generation Faults & Fixes | 8 | Feb 6th, 2006 10:09 PM |
| Power Steering Feeling Light.... | irnbru | First Generation Faults & Fixes | 0 | Feb 6th, 2006 09:29 PM |
