| First Generation MINI Cooper MINI Cooper from 2001 - 2006 |
| Hello MR .Fixit I got a question: I got a mini one from 02-2002 and i am trying to find the numbers from de bearings in the gearbox. I`m looking for 6 montsh now and still nothing. Hope you can get me some info where i could find the numbers. Because even BMW can`t give it 2 me. If you got some info for me can you mail it 2 (mh1078@live.nl) with kind regards marcel |
| Hello Johnfromaus i hope you can help me. If got a mini one from 02-2002 and i`m looking for the numbers of the bearings, but there is nobody that can help me i hope you can. If you can help me can you send an e-mail to (blakeone911@hotmail.com) with kind regards marcel |
| Bad luck, Justgot1 - I hope you can get it fixed! But have you considered trying to find a used box from a breaker? That might be cheaper...... Ian Not here much any more |
| got it back id rather pay the bit extra 2 get mine refurbed, i was scared that i fi bought a used one it would only be a matter of time before it broke, im getting it fitted on monday so il let yous know how it turns out. mini mini meep meep |
Gadavies, Any luck with your legal pursuit? I just had the same conversation with Mini North America regarding the transmission in my wife's 2002 Mini and cannot believe they would not admit some fault after all the postings about the Midlands transmission failures. If you have any guidance for those in a similar situation, I would love to hear about it. Thank you, Matt |
| 8. rover manual says to engage 1st and 5th gears to lock shafts and undo bolts. selector is different to rover box, but to achieve same the same thing on the mini box, pull lever outward and move towards diff side of case. this engages 1st. slip the disconnected synchro collar downward and presto. unstake nuts and they are actually easier to remove than i thought. Good luck with your mini[/quote] how tight do you need to tighten the nuts back up to when you are done? Tried to undo mine and man are they tight. Stopped before i got them undone as i didnt want to break anything rushing the job and do abit more research. Where other people able to undo the nuts with only locking the box by using 1st and 5th?? I already have had the end casing off. to get the middle casing off i assume you undo the input and output shaft nuts slide the gears off and then you can slide the middle off? thanks |
| TheItalIANjob Hi. I have a 2002 Cooper which is in the dealership having a new gearbox and (on their advise) clutch fitted. It does appear as this problem is wider than BMW themselves would like to admit. To make things worse, a few weeks prior to my gearbox going, my power steering pump failed. This cost £500 to be replaced, and I am still in discussion with them about it. Hope this helps. |
| Hi. I too have experienced problems with my 2002 Cooper. It's having a new gearbox fitted at the moment, plus (on their recommendation) a new clutch too! This is to cut down on any additional labour costs later on. A good idea i guess, but will probably land me with a whopper of a bill to pay now! Having read numerous other comments on here relating to the same problem, it would appear as if there is a wider problem than BMW would like to admit. To make thing worse, a few weeks prior to this, the power steering pump failed, landing me with a £500 bill. The BBC programme Watchdog covered this in some depth shortly after I had had it done. I hope this helps, Ian |
| gearbox hi all, as for my first post, i got my gearbox sorted i brought a recon box and fitted it myself. it lasted quite a wile but the prblem with the midland gearbox has come back, has anyone here ever managed to stregthen the box and stop the problems with bearing wear? cheers steve |
| Tags: gearbox |
LinkBacks (?)
LinkBack to this Thread: http://www.mini2.com/forum/first-generation-mini-cooper/145054-mini-gearbox.html | ||||
| lego gearbox instructions | VIRGILIO Ricerca | Web | This thread | Refback | Nov 30th, 2008 09:59 AM | |
| mini one gearbox | smit-one | First Generation MINI One | 13 | Dec 25th, 2010 12:15 AM |
| gearbox noise admitted by mini | northandy | First Generation Faults & Fixes | 255 | Mar 3rd, 2009 03:21 PM |
| Gearbox on 04 mini cooper? | Mull3t | First Generation Faults & Fixes | 7 | Dec 12th, 2007 08:21 PM |
| Gearbox oil change on Mini One | Adam858 | First Generation Faults & Fixes | 5 | Jul 1st, 2007 09:41 PM |
| noisey gearbox 02 reg mini one | lenno | First Generation MINI One | 0 | Feb 24th, 2007 09:33 PM |
