Power-steering fan and air conditioning down? - MINI Cooper Forum - MINI2 Mini Cooper Forums
Go Back   MINI Cooper Forum - MINI2 Mini Cooper Forums > Model Specific MINI Forums > MINI Cooper > First Generation MINI Cooper
Old Apr 13th, 2010, 01:57 AM
Local Time: 10:01 AM
Canada
I've read that the early power-steering fans such as mine (03) are exposed and prone to failure.
Mine is seized completely.
Has anyone heard about an extended warranty on those?
Could this or a resulting blown fuse have anything to do with the air-conditioning that also stopped working?
The R-134 is full, the compressor kicks in, but no cooling happening.
Thanks for your insights.
John G.
'03 R50 Automatic.
Old Apr 13th, 2010, 04:49 AM
miniFoxi's Avatar
Local Time: 12:31 AM
Australia Female View miniFoxi's Liquid Yellow & Black 1st Gen MINI Cooper S Profile
hey - i have an 03 cooper s and i had a similar problem. my secondary fan stopped working as a fuse got tripped. this fan cools the engine, power steering and airconditioner. i think it was F5 - under the bonnet. i noticed the problem because i had my aircon running and it stopped cooling. about 5 minutes later, i noticed the temperature gauge was too high and then i noticed smoke coming out from under my bonnet as the coolant was bubbling. it all worked out - got a new secondary fan and obviously had to have the fuse replaced. hope this isn't your problem as it cost me aud$989. On the plus side, all good now, no problems.
Old Apr 13th, 2010, 06:45 PM
Canada
Thanks.
I'll replace the fan and check my fuses.
John G.
Old Apr 13th, 2010, 07:01 PM
Local Time: 03:01 PM
Are you talking about the small fan attached directly to the power steering pump or the fan attached to the radiator of the car?
As for the air-con, if the compressor is kicking in there must be sufficient pressure in the system. Possibly just needs a proper service if you haven't already had it ie system flushed, correct amount of refrigerant and lube added then pressurised.
Old Apr 13th, 2010, 11:51 PM
miniFoxi's Avatar
Quote: Originally Posted by brinks (original)
Are you talking about the small fan attached directly to the power steering pump or the fan attached to the radiator of the car?.
believe it or not, this also had to be replaced on my mini! so frustrating - the little fan attached to the steering pump used to stop working when overheated and that affected my power steering (used to go hard - minis are much heavier than they look!), but did not affect my airconditioner. had to replace the steering pump the same week as the secondary fan. Very expensive week!
she's back on the road now and drives a dream...
Tags: , , ,
Power Steering goes out, high speed fan and power steering fan aren't staying on. Niko First Generation Faults & Fixes 3 Jul 7th, 2008 01:25 PM
power steering fan. holdenontoit First Generation Faults & Fixes 5 Jan 17th, 2006 09:45 PM
Power Steering Fan Shroud RVW Maintenance & MINI Care 7 Jul 30th, 2005 05:29 PM
Power steering fan is gone! thanos30 First Generation Faults & Fixes 4 Mar 21st, 2005 06:07 PM
I don't have a power steering fan! Dom General Discussion 20 Mar 19th, 2005 12:11 PM
