2003 Mini Cooper wheel alignment settings? - MINI Cooper Forum - MINI2 Mini Cooper Forums
Go Back   MINI Cooper Forum - MINI2 Mini Cooper Forums > Model Specific MINI Forums > MINI Cooper > First Generation MINI Cooper
Old Jun 19th, 2011, 09:16 PM
Local Time: 04:19 PM
Hey getting my other half's Mini Cooper wheel alignment done tomorrow, it's 2003 and has the 175 pirelli p6000 tyres on the 15" wheels.
Just wondering if anyone has accurate settings as I'm taking it to kwikfit for the meanwhile and they can tend to be clueless most of the time and go by wall charts for the settings
Any help ASAP is much appreciated
Old Jun 20th, 2011, 10:00 AM
Bump! Anyone know the settings!? It's the p3000 tyres too, sorry....
Old Jun 20th, 2011, 04:42 PM
cristo's Avatar
BLIKSEM (my brg/brg mc)
Local Time: 12:19 PM
United States Male View cristo's British Racing Green & Body Color 1st Gen MINI Cooper Profile
Front Camber -0.5 degrees +/- 0.5 - (i.e. 0 to -1.0 degrees) not adjustable, if it's off, something's bent -
can buy and install camber plates to adjust - this will raise ride height a little.
Front Toe is about 0.2 degrees toe in (or about 1/8 inch) - I'd set them to 0 or 1/16" toe in myself.
Rear Camber -1.5 degrees +/- 0.5 (i.e. -1.0 to -2.0 degrees)- not adjustable on a 2003, if it's off, something's bent
can buy and install 2 or 4 adjustable rear control arms to adjust.
Most people would set in the -1.0 to -1.5 range in that case.
Rear toe is about 0.3 degrees (or about 3/16 inch) - I'd set them to 1/16 - 1/8" toe in myself
- can be adjusted by moving the trailing arm bolt positions
I forget the front caster spec - but it's in my Bentley and Haynes manuals at home (non-adjustable stock -
there are two ways to change it with aftermarket parts, however - certain camber/caster plates and certain control arm bushing replacements).
If you need them and/or a more precise regurgitation of the toe in values, I can look them up and post them tonight when I get home.
Old Jun 20th, 2011, 05:39 PM
cristo's Avatar
This is a post from Tit from 2005- straight out of the Bentley Manual:
Bently manual reckons post may 03 there was no alignment spec changes....from the manual:
Front Wheel alignment Specifications
Parameter Specs
Toe angel (total) 0° 18' ± 5'
Camber (difference between left/right max. 30') -30' ± 25'
Track offset angle (20° Steer angle on inside wheel) -1° 16' ± 30'
Caster (difference between left/right max 30')
with ± 10° steer angle 4° 47' ± 30'
with ± 20° steer angle 4° 55' ± 30'
Front wheel offset (max steer angle)
inside wheel aprox 36° 10'
outside wheel aprox 30° 36'
Rear Wheel alignment specifications
Parameter Specs
Toe angle (total) 0° 24' ± 8'
Camber (difference between left/right max. 30') -1° 32' ± 30'
Geometrical axis difference 0° ± 10'
Anyone know what are the suspension & steering alignment settings for R56 MCS with SS JohnWB Second Generation MINI Suspension 1 Sep 17th, 2007 02:20 PM
Wheel Alignment for MINI brucesax Wheels, Tyres & Brakes 1 May 6th, 2006 03:47 PM
Cooper S wheel alignment in Sydney ??? red5 Australia 10 Mar 5th, 2006 03:46 AM
Wheel Alignment settings - Stock GTT 280 Wheels, Tyres & Brakes 7 Mar 21st, 2005 02:52 AM
Wheel Alignment Settings JME First Generation MINI Tuning 0 May 18th, 2004 04:45 AM
