2003 Mini Cooper Midland Gear Box Oil Change - MINI Cooper Forum - MINI2 Mini Cooper Forums
Go Back   MINI Cooper Forum - MINI2 Mini Cooper Forums > Model Specific MINI Forums > MINI Cooper > First Generation MINI Cooper
Old Sep 8th, 2011, 12:31 PM
Local Time: 03:02 PM
Hi,
Only had my Mini Cooper for a few weeks now and at present there are no problems with the gearbox (touches wood). However, having read a few posts re oil changes on this forum I decided to change the gear box oil.
Was relatively straight forward, got the correct MTF 94 oil on ebay (Unipart). The top plug was a bit difficult to losen but it moved eventually. Drained the oil out and here are the magnetic plugs with 56000 miles worth of swarf!!
As I say the gear changes are fine so not sure if I notice a difference but at least it is a job done for another few miles.
Regards
Old Sep 8th, 2011, 04:42 PM
mab01uk's Avatar
Well worth doing..........I will link your pictures into my other posts on this topic for future reference of others.
Tip: Always loosen off the filler plug on the gearbox first.......otherwise draining the oil out first via the bottom drain plug means if you can't then undo the upper filler plug, the car can not be driven as you have no oil in the gearbox and no way of filling it to take it to a garage for help!
Old Sep 8th, 2011, 05:13 PM
That amount of swarf is normal, you can fill it through the vent if the top plug proves to be tight, just put in a measured amount.....
Old Nov 5th, 2011, 04:33 PM
Local Time: 02:02 PM
Just done the gearbox oil change on a 2001 Cooper.
The fill plug was "Holding the car together" tight.
Had to take the wheel off and use a few socket extensions and a pull bar the loosen it.
Filled it back up with Redline MTL.
Gear change now feels a lot smoother.
Cooper S gear change rebeccamini Second Generation MINI Cooper S 3 Dec 18th, 2009 07:47 PM
2007 MINI COOPER R56 sticky gear change 1st to 2nd gear hankdu Second Generation MINI Cooper 1 Aug 31st, 2008 08:17 PM
Cooper S - clunky gear change brighton_mcs First Generation Faults & Fixes 4 Feb 6th, 2006 09:22 PM
DIY to change the gear knob for CVT cooper ken206 First Generation Interior & Ice 1 Sep 13th, 2004 04:23 PM
CVT cooper gets sterring wheel mounted gear change!! B4d4Bing First Generation CVT & Automatic 25 May 2nd, 2003 12:33 AM
