| First Generation MINI Cooper MINI Cooper from 2001 - 2006 |
spark plug strangeness 2 14 NOV 2011 Okay, I had a problem months ago when I noticed the round rubber seal around spark plug #3 was flexing like a sub woofer. Pulled the wire and found the spark plug was loose ... so I tightened it and all was fine. So today I pull my mighty MINI into the garage and as soon as I turned off the key, the motor's fan came on. I thought that was strange, but once had the fan and plug melt down (when the fan came on and it eventually drained the battery and got so hot it melted the wiring harness to the fan) ... so I was preparing to disconnect the battery to keep this from happening again. So the bonnet was open and I was searching for a wrench ... which I didn't have in the garage, so I decided that I would re-start the car while I ran to get the wrench. As soon as I turned the key, there was a loud explosion (louder than a fire cracker, not as loud as a M-80)! I immediately turned off the key and noticed the fan was no longer running. I got out of the car and looked in the engine by to find 1. the spark plug wire for #3 was no longer in place ... and 2. the spark plug (from #3) was laying across the garage on the floor as it had blown out of the engine!! That plug's threads look fine, so I'm assuming it had worked it's way loose again and that the cylinder head isn't trashed in the explosion ... though I don't yet know... and will have the car inspected tomorrow at my local garage (Auto4N in Cincinnati) Anyone ever see such a thing? |
| Heard of a few Mini plugs working loose and sometimes get blown out but often damages the thread, meaning head off for a helicoil or can be done in situ by using 'Time-Sert' Wrth UK Ltd. - the world's number one supplier of assembly products and consumables Successful Mini2 repair here: http://www.mini2.com/forum/first-gen...eads-help.html |
| It seems more common on R50/53 Mk1 Mini's, but does also happen on other makes and types of car. I think this is due to the much longer spark plug service intervals than in the past on modern cars. Plugs now have more chance to work loose over a longer time or the opposite where they seize/corrode into the cylinder head. The thread damage is caused by the loose plug wobbling around during each cylinder compression and then finally flying out under pressure strips the remaining few threads hanging on........... |
| Tags: cylinder head, engine, spark plug |
| Spark plug gap | Wez007 | First Generation MINI Tuning | 0 | Jun 16th, 2009 08:20 AM |
| Spark plug help... | dr remulac | First Generation MINI Tuning | 0 | Jul 5th, 2005 04:23 PM |
| Spark Plug | E-Gun | Maintenance & MINI Care | 6 | Feb 5th, 2005 05:57 AM |
| spark plug gap | ASTON | Maintenance & MINI Care | 5 | Feb 16th, 2004 12:20 PM |
