R50 Strange central locking issue - MINI Cooper Forum - MINI2 Mini Cooper Forums
Go Back   MINI Cooper Forum - MINI2 Mini Cooper Forums > Model Specific MINI Forums > MINI Cooper > First Generation MINI Cooper
Old Dec 10th, 2011, 08:18 PM
R50 Newbie
Local Time: 02:02 PM
United-Kingdom R50 Strange central locking issue
Hi,
Ok, well it would be really great to get some help with a central locking issue that ive got with the R50.
Initially thought it was the BC1, then the drivers door lock - now I just don't have a clue...
In the car, you can use the toggle and it works no problems.
If you use either the fob or the key in the lock - the car locks then immediately unlocks.
If you take the battery off for 5 minutes, put it back on, the locking system works no problems. Soon as you jump in start it up - try the fob or key in the door it's back to square one - locks/alarm on/alarm off/unlocks.
So frustrating....
Any ideas?
Personally I've thought (and with help from others):
Fob is fine - as it also does it with key in door.
Door lock is fine as straight after putting the battery back on doors work a-ok.
BC1 is fine, only seems to effect doors-surely more would be wrong if it was the BC1?
Any thoughts guys???? Could it be the battery ? Needs a top-up? Car starts fine every time..
Maybe an earth????
Help..........
Really appreciate your help
Old Dec 11th, 2011, 12:31 AM
Local Time: 07:02 AM
United States Male
Hello, I'm pretty unfamiliar with the r50 so bare with me. Does the r50 have a convienience option? As in the proximity door unlocking from the fob?
Old Dec 11th, 2011, 08:35 AM
R50 Newbie
Yellow Cooper
Hey Bmont82,
I'm not quite sure what you mean, yes it has unlocking via the fob from close proximity?
Could you explain abit more (sorry).
Regards,
Neil
Old Dec 11th, 2011, 04:18 PM
R50 Newbie
Quote: Originally Posted by R50_Neil (original)
Hey Bmont82,
Regards,
Neil
Hey folks, all resolved... A 5A fuse on the alarm after all that goings-on!!!
Happy times
Central Locking issue ? jenilovesherminimoo First Generation Faults & Fixes 0 Feb 20th, 2011 06:15 PM
Central Locking Issue Joshleigh1 First Generation Faults & Fixes 3 Sep 3rd, 2010 10:21 PM
help required please - central locking - strange! Dan86_mcs Maintenance & MINI Care 3 Nov 9th, 2009 08:25 AM
Strange problem with central locking stuartfoster Maintenance & MINI Care 4 Apr 21st, 2008 06:08 AM
Strange fault with Central locking while driving M11NYL First Generation Faults & Fixes 6 Aug 10th, 2006 01:57 PM
