K & N Air Induction Kit 57i vs K & N Panel Filter - MINI Cooper Forum - MINI2 Mini Cooper Forums
Go Back   MINI Cooper Forum - MINI2 Mini Cooper Forums > Model Specific MINI Forums > MINI Cooper > First Generation MINI Cooper
Old Dec 20th, 2011, 08:38 AM
mkoolb's Avatar
Local Time: 03:02 PM
United-Kingdom K & N Air Induction Kit 57i vs K & N Panel Filter
I am thinking of fitting an Air Induction Kit to my stock mini cooper R50[2002] engine to make it sound a bit louder The problem is I called a supplier who told me fitting an air induction kit in a standard mini cooper without supercharger will result in a loss of power.
Now I am not sure if this is right??? Is that because the air induction kit will suck hot air from the engine this in turn makes the car loose power?
In this case will it be better just to replace the existing paper filter for a K&N Panel Filter?
Anyone who has got a standard stock mini cooper engine and has got the Air Induction Kit fitted, it will be great to get some feedback?
Old Dec 21st, 2011, 08:21 AM
mkoolb's Avatar
71 view and not a single reply
Old Jan 10th, 2012, 09:13 AM
TC-TOM's Avatar
TC-TOM
Local Time: 02:02 PM
United-Kingdom panel vs induction
I have this same question...can someone please shed some light on this
Old Jan 10th, 2012, 11:55 AM
Hi guys
I would not totaly agree with loosing power with an induction kit. The main thing you need is lots of cool air. Fitting an induction kit will allow hot engine air to be suck in to the inlet causing loss of power, but if you can get lots of fresh air to it it will work well.
You can get good results with a panel filter and modify the airbox. The nice thing with this option is it looks standard
I use this type of filter in my MCS but this link is for yours
https://www.vecchio.co.uk/index.php?...mart&Itemid=55
Old Jan 10th, 2012, 12:05 PM
United Kingdom View Poprin's Classified Ads
Hello chaps,
Yes basically what Marque said. In order for induction kit to work you need cold air to get sucked into it. I don't know why the supplier said a cold air induction kit would not work on a non-supercharged car. Feel free to correct me if i'm wrong people but that's b*ll*cks!
A cold air induction kit will work on any engine, the cooler the air that gets into the combustion chamber the more power you get. Unless the supplier only has an induction kit for a supercharged model and the kit isn't positioned to get cold air into the system well...
Only speculating.... maybe speak to a different supplier
Old Jan 10th, 2012, 12:41 PM
United Kingdom View sad61t's Pepper White & Body Color 2nd Gen MINI Cooper Profile
The easiest change is to fit a new high-flow panel filter. I've done this previously on a Skoda and a Megane (both normally aspirated) and it made a small, but noticeable, difference. It also has the advantage of being 'stealth' as regards insurance and MOTs.
Also used an aftermarket pancake filter that was within the engine bay of a kit car. Chrome bling, but less performance so swapped back to the OEM black wheelie bin unless it was on show.
If the kit is just a cone filter tucked in the back of the engine-bay then the extra flow will be negated by the lower density of hot engine-bay air. If you decide to go down that route, look for a kit that encloses the cone and includes a pipe to take fresh air from the current intake behind the front grill (looking at an R56 Cooper).
Old Jan 24th, 2012, 07:03 PM
02caretaker's Avatar
I agree about the panel filter change I put a K&N one on every car I have as a matter of course, economy goes up and usualy a little increase in mid range poke. I have also used the i57 kits but they come with an increase in induction noise.
Old Jan 30th, 2012, 09:18 PM
I've had a K&N panel filter in my 05 Cooper for 20,000 miles. A slight increase in inlet roar and pick up (although the original paper panel filter was minging!). I've cleaned it twice as it does pick up lots of flies and road dirt - better on the filter than downthe intake!
I've had cold air filters on other cars and "yes" they are louder, but to be quite honest, on their own, you will not see any appreciable performance gain. Unless you force cold air from 0-30mph then you will little change to 0-60 times. Personally, I would save your money and buy the panel filter if that is the only mod you plan on doing (however, if you plan a manifold change, cat-back free flow and a re-map then it might just be worth it).
Gaz
Panel or Induction kit ? jimkim General Discussion 5 Oct 30th, 2011 11:20 PM
What PANEL Air Filter to Use? n733lk Second Generation MINI Tuning 19 Jun 26th, 2009 03:30 PM
Best panel air filter? chrisrue@btinternet First Generation MINI Tuning 3 Jan 20th, 2009 06:57 PM
induction kit or panel filter replacement!? ianw12345 First Generation MINI Tuning 12 Jul 19th, 2005 03:19 PM
Panel or induction minibee First Generation MINI Cooper S 10 Feb 27th, 2004 11:21 AM
