| First Generation MINI Cooper MINI Cooper from 2001 - 2006 |
| Still unsolved - Rubbing noise My 2003 MC has a rubbing noise in the front right (drivers side) wheel well that I can't pin point. SO aggravating. It's not a metal noise or grinding noise or thumping noise...just a low rubbing noise like rubber rubbing against something that sounds like "whoop, whoop, whoop". I can only really hear it when I drive under 30ish MPH. I've changed the brake pads and checked the parts associated with wheel, wheel bearings and what not. So perplexed on what it could be. |
| Well, since I've had no replies, I will update everyone on my problem. I found out the other day that I need to replace the cv axle on the drivers side (I replace the passenger side one a couple weeks ago. I am hoping that the noise might be coming from the shaft or that when I pull the axle out of the wheel I can find the source. Wish me luck! |
| I am happy to report that my MINI is fixed! No more sound coming out of the wheel well on the passenger side when I replaced the CV axle. I can only assume that the boot on the broken shaft was rubbing up against the tire or a piece of the suspension. I am totally relieved. I also replaced both sway bar end links which helped the handling a ton. --->This girl is a happy girl now!<--- Thank you for all your help! |
| Grinding/ rubbing noise ? | Wez007 | Second Generation Faults & Fixes | 0 | Mar 2nd, 2010 06:05 PM |
| Wheel Rubbing Noise | Stimmo | Maintenance & MINI Care | 2 | Jan 2nd, 2009 09:57 AM |
| Rubbing noise | Janoose | Maintenance & MINI Care | 1 | Jun 18th, 2008 09:24 PM |
| Rubbing/squeaking noise | oohmatron | First Generation Faults & Fixes | 0 | Dec 26th, 2006 10:12 PM |
| rubbing noise from LSD | Ganoush | First Generation Faults & Fixes | 6 | Jan 31st, 2006 12:14 PM |
