Advice on how to Remove a mini door please (2004) - - MINI Cooper Forum - MINI2 Mini Cooper Forums
Go Back   MINI Cooper Forum - MINI2 Mini Cooper Forums > Model Specific MINI Forums > MINI Cooper > First Generation MINI Cooper
Old Jan 22nd, 2012, 10:18 PM
Local Time: 02:03 PM
Having had a kind soul hit my passenger door I am about to buy a new (second hand) one and replace it myself. Any advice on the best way of doing this and tools etc would be gratefully appreciated. Car is R50 - 2004.
Old Jan 22nd, 2012, 11:00 PM
mab01uk's Avatar
Local Time: 03:03 PM
Here is a start!
How to remove the door brake/check strap:
Door check straps, anyone changed them? - Page 2 - totalMINI Forums
Door Panel Removal
Old Jan 22nd, 2012, 11:15 PM
Hi
Make shore you buy your self some low tack masking tape. cover anywhere you think you might need to protect your paint better to damage tape than paint.
You will need to adjust the window as well.
Get your door adjusted correctly first door shut gaps and closing properly then adjust the window or you might brake it
I used a trolley jack and a bit of 6x2 wood and a towel to support the door makes it abit Easyer to handle make shore you have a helper
http://www.mini2.com/forum/general-d...djustment.html
Old Jan 23rd, 2012, 10:04 PM
How long
Thanks for the info guys. How long do you suggest it will take from removing to replacing door with maybe a little bit of messing about?
Advice on Roof rack for Mini Cooper 1 (2004) mlees General Discussion 1 Mar 18th, 2010 06:26 PM
How to remove door card on R56? lee Second Generation Interior & Ice 7 Mar 18th, 2009 11:31 PM
How to remove glove box door? Corky First Generation MINI Cooper 1 May 25th, 2007 03:13 PM
How do I remove my Door Cards? wreelybro First Generation Faults & Fixes 3 Jul 28th, 2005 03:54 PM
Thinking of buying a 2004 mini cvt.need advice crow guy General Discussion 6 Jan 21st, 2004 09:02 PM
