Tyre monitoring? - MINI Cooper Forum - MINI2 Mini Cooper Forums
Go Back   MINI Cooper Forum - MINI2 Mini Cooper Forums > Model Specific MINI Forums > MINI Cooper > First Generation MINI Cooper
Old Jan 25th, 2012, 02:36 PM
02caretaker's Avatar
Local Time: 03:03 PM
Electic Blue S Tyre monitoring?
My 56 plate cooper park lane has the puncture detection system button by the handbreak, I know about the activation of it after each presure check but how does it actualy monitor the tyres i cant find any sensors.
Old Jan 25th, 2012, 02:56 PM
Hi
Tire pressure monitoring is carried out by diferentatal wheel speeds. This is calculated buy the cars computer. when the is a difference between wheel speeds of a set pecenage it will trigger the system.
If you set you tire pressures to spec then reset your monitor system this sets the datum this also puts you traction control and stabilty control in to learning mod.
There is no need to do this every time you check or reset the pressuress.
Hope this helps
Old Jan 25th, 2012, 07:38 PM
Thanks for that all interesting stuff
Tags: ,
Ideal tyre size for my wheel & tyre combo Azero Wheels, Tyres & Brakes 2 Apr 21st, 2011 06:39 PM
MINI tire pressure monitoring system Adrian Wheels, Tyres & Brakes 7 Dec 4th, 2004 03:38 PM
