| First Generation MINI Cooper MINI Cooper from 2001 - 2006 |
Mini Cooper 2003 cold start issue Hi every1. The temperatures have been very low and snow this week its been -6c to 0c. Car has been parked outside for 5 days under the cold and snowy weather.I tried starting it and no luck. All i could hear is the sound tak.tak..tak i am guessing the battery is almost dead. Tried the wipers and the radio they work but the car don't start. The starter motor does not even bother. Any suggestion much appreciated! Thanks in advance. ![]() |
| Hi sound like your battery is on it way out if it is the original one it will most probarbly need changing you can try charging it if you Want. or even jump starting it, if it jump starts it a good possibility it the battery. when you get it running put a volt Meter across the battery and make shore you have at least 12.5 volts dc this will give you a good indication if you alternator is working hope thus helps |
| Tags: battery |
| Cold Start Issue | Bing | First Generation MINI Cooper S | 29 | Nov 5th, 2011 01:19 PM |
| Won't start.......................NOT cold start issue | Rwatts4mini | First Generation Faults & Fixes | 2 | Nov 5th, 2011 01:16 PM |
| R56 MCS Cold Start Issue | Boro Boy | Second Generation Faults & Fixes | 8 | Mar 6th, 2008 04:21 PM |
| My cold start issue is now a warm start issue | FrenchCori | First Generation Faults & Fixes | 0 | Mar 31st, 2006 10:39 PM |
| Will not start period....NOT Cold Start Issue | Silly | First Generation Faults & Fixes | 31 | Aug 5th, 2002 02:35 PM |
