Need help please ! - MINI Cooper Forum - MINI2 Mini Cooper Forums
Go Back   MINI Cooper Forum - MINI2 Mini Cooper Forums > Model Specific MINI Forums > MINI Cooper > First Generation MINI Cooper
Old Nov 19th, 2012, 08:06 PM
Online
Local Time: 04:40 PM
Need help please !
Hi , ive got a first generation mini cooper S on a 52 plate and it needs a supercharger bearing , does anybody know if just the bearing can be replaced or if i need to replace the whole supercharger ?
Also does anyone know of any supercharger specialists in manchester ?
Thanks in advance .
Old Nov 19th, 2012, 09:10 PM
Hi
The supercharges can be repaired if you have the right tools. The SC will have to be removed to do any repair work. Which bearings have gone
This a snot rebuild kit
Eaton M45 Supercharger Snout Rebuild Repair Bearing Kit | eBay
Depending on the mileage and condition it my be worth swapping it for a good secondhand one of eBay
BMW Mini Eaton Supercharger | eBay
Hope this helps
Old Nov 19th, 2012, 11:52 PM
Online
Nice one for the reply , the cars done 87000 so think its worth replacing but I only bought it 6 weeks ago so hopefully the garage I bought it from will replace it ,they've already taken it to go and get a second opinion 'cause I was quoted £1300 for a new replacement . Only found out it was the supercharger bearing this morning 'cause me and my mechanic thought it was just a drive belt pulley due to a squealing noise from the engine
I haven't got a clue what bearing it is , but I would've expected a loss in power with a supercharger fault ? Still pulls fine.
Old Nov 20th, 2012, 02:45 PM
Hi ya
If they are going to fit a second hand one make sure they change and check the oil in both ends of the super charger before fitting it. And make sure its the correct oil.
Old Nov 20th, 2012, 02:50 PM
If the bearing has gone and theres play present now in the shaft, continued use will probably grind the scrolls away and ruin the whole thing.
Old Nov 20th, 2012, 03:50 PM
Online
Smile
Quote: Originally Posted by marque (original)
Hi ya
Cheers for the advice mate , now I've been told hat it's just the drive belt but I think I'm gonna buy a used supercharger just incase it isn't the drive belt
