System pressure cap seems ok,i have tried the original and the new one that came with the thermostat housing.Two speed fan is working as far as i can tell,the coolant gets hot fairly quickly around the right side of the engine around the thermo housing and pipes but the heater pipes remain cold and hot water doesn`t seem to circulate.
I am going to remove the jiggle pin from the new thermostat and investigate the pump,some of the other posts point towards head gasket failure
Steve
