Hello,
My sensor light came on, and it is that time. This will be my first time to change the brakes on my R50 since I got it. I wanted to take the opportunity to upgrade my rotors, calipers, brake pads, brake lines, etc. I have found a vendor to purchase the
JCW brake kit from. I purchased EBC D939 & D1060 brake pads as well as EBC GD1007 and GD1008 3GD rotors. Will the
JCW kit above work with the parts above? I noticed the rotors are not the same size as the rotors that come in the kit. Will I be able to use the rotors I purchased with the kit, or will I need to find an alternative. If I need to, I have the option to return the rotors and brake pads. If so, what would you all recommend?
Motor On!
