Battery drain problem - MINI Cooper Forum
Go Back   MINI Cooper Forum > Model Specific MINI Forums > MINI Cooper > First Generation MINI Cooper
Power steering not working & Battery light on (This is a strange one!) Plungerrr First Generation Faults & Fixes 1 Dec 27th, 2013 07:22 PM
Battery Advice Oldpaint Maintenance & MINI Care 2 Aug 30th, 2013 10:22 AM
Extreme Battery drain on JCW RachyS First Generation Faults & Fixes 9 May 7th, 2013 10:43 PM
Water in passenger foot well and battery drain boggey79 Second Generation Faults & Fixes 5 Jan 18th, 2013 02:18 AM
Usual Battery Drain SteelPriest First Generation Faults & Fixes 7 Nov 13th, 2012 06:52 AM
Old Dec 29th, 2013, 07:15 PM
Local Time: 05:31 AM
Hi All,
Apologies if this has been covered elsewhere in a thread but i couldn't find anything. I have a 2006 1st gen Cooper and have an ongoing battery problem. I've had the car about 2 months and have been plagued with flat battery problems. The battery kept going flat despite being driven regularly. We had a battery test at Kwik fit and they said the battery was fine so i just gave it a full charge on a charge and it seemed fine. Then about 2 weeks ago, after driving the previous day for about 90miles, the battery was totally flat. I phoned the AA and they sent a battery assist van who said the battery needed changing so i shelled out 100 for a new battery. Then after 2 weeks the battery was flat again. So something is draining the battery although all the systems seem to be ignition live. The only thing i can think of that is causing the problem is the Bury 9060 handfree kit, but would that drain the battery in 12 hours?
Any ideas?
Thnaks
Hoggy1972
Old Dec 29th, 2013, 07:40 PM
Local Time: 06:31 AM
United Kingdom Male View Blusox's Laser Blue & Body Color 1st Gen MINI Cooper S Profile View Blusox's Classified Ads
Is everything on the car standard? How about the head unit or after market amp?
Old Dec 29th, 2013, 08:00 PM
As far as I know it is all factory fitted kit, It does have the Harmon karden upgrade though.
Old Dec 30th, 2013, 12:16 PM
Battery Problems
When you had the battery changed by the AA did they do a complete check on the charging circuit of your electrics?
You know the battery is good, but do you know that it is being correctly charged when you are driving it?
I have had problems like this in the past (not on a new MINI though) and it is more likely to be a problem with the alternator charging, or earth lead issues than something draining the power this quickly.
However, I have come across alarms and CD changer units draining power quicker than they should....but this is usually down to an inadequate battery being fitted to the car.
Spike
Old Dec 30th, 2013, 08:47 PM
Restyle's Avatar
Damned
United Kingdom Male View Restyle's Hyper Blue & White 1st Gen MINI Cooper S Profile View Restyle's Classified Ads
I had this problem recently where if I hadnt run the car for 4 days then battery would be flat.
I also swapped for new battery to no avail.
Turned out mine was a fault with the HK amp - but could be anything
Here's how you find out ....
You 1st need a multimeter which can read current of at least 10 Amps
Such as >> This This
If not autoranging, Set meter to the 10A scale, get in car, turn ignition off.
Then 1 by 1, remove each fuse in turn & put probes across each set of revealed terminals.
Some will normally have a small current, such as alarm system & elect windows surprisingly, of say up to 200ma {1/5 amp}.
But you've got to look at those, say above 500ma, on circuits that should'nt have power with ignition off.
Hopefully this will give you some idea of the circuit that is causing the drain that you can investigate in more depth.
Old Feb 5th, 2014, 03:25 PM
United States Male
Red face elec power drain
I have to agree on all of that!
Name:	LR-1 - 2856857517_f6554a8b0c_m.jpg
ID:	168754   Click image for larger version
Name:	Chip's Pix 016.jpg
» Recent Threads
Does your Mini have a name?
Mar 25th, 2014 10:00 PM
Last post by johnnycatbiscuit
Today 04:26 AM
17 Replies, 986 Views
Engine mounts
Dec 22nd, 2013 07:47 PM
Today 04:21 AM
3 Replies, 768 Views
Buying a cat D insurance loss
Apr 4th, 2014 09:12 PM
Today 04:18 AM
9 Replies, 418 Views
Central Locking Problem Help
Yesterday 04:19 PM
Last post by heathwebbo
Today 12:17 AM
3 Replies, 153 Views
should I wait or not?
Apr 14th, 2014 12:07 AM
Last post by drozd
Today 12:08 AM
6 Replies, 371 Views
Lost locking wheel nut key
Apr 6th, 2014 10:49 AM
by Dazza88
Last post by drozd
Today 12:01 AM
3 Replies, 210 Views
NAVIGATION FIRMWARE dvd
Apr 5th, 2014 03:06 PM
Last post by drozd
Yesterday 11:47 PM
1 Replies, 180 Views
Mini One Silver 2004. FOR SALE
Yesterday 06:58 PM
by 93dlei
Last post by 93dlei
Yesterday 06:58 PM
0 Replies, 84 Views
Will this rear bike rack work on the Clubman?
Jun 6th, 2011 10:18 PM
Last post by sailesh
Yesterday 06:00 PM
3 Replies, 3,933 Views
Which Used Mini
Yesterday 12:31 AM
by UKNY
Last post by UKNY
Yesterday 05:09 PM
6 Replies, 211 Views
Where can I buy Spare wheel carrier for r50!
Apr 16th, 2014 07:28 PM
Last post by mab01uk
Yesterday 05:06 PM
3 Replies, 183 Views
New to this! No hot air in the car!
Apr 16th, 2014 03:37 PM
Yesterday 05:04 PM
7 Replies, 253 Views
2007 Cooper D (r56) - How to look after her and what to look for when buying
Apr 15th, 2014 01:10 PM
by hyvrid
Last post by hyvrid
Yesterday 03:44 PM
6 Replies, 329 Views
Radio CD Player Spare Part
Yesterday 10:47 AM
by B20A
Last post by Caveman
Yesterday 03:42 PM
1 Replies, 100 Views
First Mini Help !
Apr 13th, 2014 08:19 PM
Last post by The Nun
Yesterday 01:44 PM
5 Replies, 237 Views
Tyre pressure on dash board
Apr 14th, 2014 01:59 PM
by ajn
Last post by carbon337
Yesterday 12:23 PM
2 Replies, 188 Views
Tyre pressure light and weird handbrake relationship
Mar 28th, 2014 06:48 PM
Yesterday 12:18 PM
4 Replies, 398 Views
Brake wear sensor or not ?
Mar 13th, 2014 12:49 AM
Last post by Milpol
Yesterday 11:59 AM
4 Replies, 487 Views
Problems with remote amp lead in trunk
Apr 5th, 2014 09:57 PM
by nize
Last post by nize
Yesterday 11:18 AM
2 Replies, 277 Views
what your factory frequency response looks like
Mar 5th, 2014 02:36 AM
Last post by rumblestrip
Yesterday 10:22 AM
1 Replies, 436 Views
Wheel & Tire Center
