2004 cooper not start - MINI Cooper Forum
post #1 of 4 (permalink) Old Jan 3rd, 2014, 02:01 PM Thread Starter
Local Time: 07:18 AM
United-Kingdom 2004 cooper not start
hi all new user ,just been given a 2004 cooper , been standing for a couple of years so fitted a new battery only have 1 key that worked the central locking on placing the key in ignition all lights come on and go out except eml and will not turn engine over , fuel pump works as I can hear it, been under to starter and jumped contact with 12 volts and it turns over ,tried to bump start but wont start does anyone have some ideas , don't minding spending some money as its a nice car , much apreciated
carpeys is offline
post #2 of 4 (permalink) Old Jan 3rd, 2014, 09:15 PM
MangaGal's Avatar
Local Time: 05:18 PM
Australia
Is the car key original key? If it hasn't been driven for a while, it's likely that the key is totally out of battery. From what my mechanic told me, the key's battery charges from being in the ignition.
If the key hasn't been used for a couple of years, you should try getting a new key. (Someone please correct me if I'm wrong).
A new car is pretty expensive because BMW needs to programme it to suit your car. I paid AUD500+ for a new key when it died. Mind you, it isn't as expensive as getting a new car.
Good luck!
MangaGal is offline
post #3 of 4 (permalink) Old Jan 4th, 2014, 03:59 PM Thread Starter
thanks for the reply but the key works the central locking fine and lights up the instrument panel so if it was the key wouldn't those items not work then ?
carpeys is offline
post #4 of 4 (permalink) Old Jan 29th, 2014, 08:03 PM
Valvashon's Avatar
Local Time: 11:18 PM
Quoted: 5 Post(s)
United States Male
The battery in the '04 key is user replaceable- it is a CR2032. But its only function is to run the remote for the central locking system. It sounds like your immobilizer isn't recognizing the EWS chip that is inside the key.
Try this: Car battery connected, door open, put your key in the ignition but don't turn it at all. If you hear a "ding" the immobilizer has recognized the EWS chip in the key and will allow 12v+ to flow to the starter motor and ignition. If not, that's the first thing that needs to be looked at. It is possible but highly unlikely that the EWS chip has been removed from the key. I don't know why somebody would do that. If you want to open up your key and look it is a somewhat rectangular shaped thing held in the key shell with a small plastic tab. I have a thread on here somewhere that shows pictures of an opened key you can compare it to. If your immobilizer/EWS system isn't working, it might be time for a trip to a dealer, or to call around to an independent MINI shop. They are highly complex systems.
Val
Valvashon is offline
R56 Mini Cooper Erratic surging at idle from cold start Norfolk-Mini Second Generation Faults & Fixes 7 Mar 23rd, 2016 01:42 AM
Can you Jump start a Mini Cooper Mini Tony Welcome New Members 7 Jun 11th, 2015 11:25 AM
Automatic 2003 Mini Cooper wouldn't start and codes P1698 & P1787 were shown. Tyna Welcome New Members 2 Nov 12th, 2013 05:47 PM
'07 cooper s wont start after loose tensioner. Timing? geekycraig Maintenance & MINI Care 0 Oct 3rd, 2012 06:03 PM
06 Cooper cranks but doesn't start durchland First Generation Faults & Fixes 4 Sep 27th, 2012 10:13 AM
