Help! R50 engine tick/knock - MINI Cooper Forum
post #1 of 1 (permalink) Old Mar 31st, 2014, 03:00 PM Thread Starter
Local Time: 06:39 PM
Silver Black Help! R50 engine tick/knock
Hi I just joined the forums to get some help thoug I have been visiting and reading all your guys problems about power steering failure and TC tensioner. So my problem is I have an 02 mini r50 that developed back in August and the cat has been parked since. I had thought from research an hearing clips on YouTube that I diagnosed the problem as the timing chain tensioner so yesterday I replaced t. First off I think it was almost too easy. I didn't have to move the car fore or aft to get it to slide in nor did I have to push hrd to get the head screw to compress the tensioner enough to catch threads. Now I wouldn't be questioning anything if the knock went away when I changed the tensioner however it's still there. One more twist to this is there's a point when releasing the clutch at the moment the gear catches the sound will stop for a split second. However depressing the clutch in drive or neutral doesnt change a sound just te release as gear catches. I'm thinkin maybe a chain guard or stretched chain, maybe a lifter or something in the engine. I no mechanic just have some tools and a little know how. Please help me
Backwoodsbasser is offline
Tags: , , ,
Time Chain Tensioner failure and Engine shut down jhl2435 Second Generation Faults & Fixes 2 Mar 1st, 2014 07:45 PM
Mini engine dispute SarahH General Discussion 9 Dec 11th, 2013 10:39 PM
R50 engine starts but.. Rally370 First Generation MINI Cooper 4 Apr 18th, 2013 01:53 PM
Cracked engine block? Help please?! rhutch First Generation MINI Cooper 2 Dec 16th, 2012 10:24 PM
BMW three-cylinder MINI engine revealed mab01uk MINI in the Media 1 Oct 9th, 2012 10:42 PM
