Memory Options - MINI Cooper Forum - MINI2 Mini Cooper Forums
Go Back   MINI Cooper Forum - MINI2 Mini Cooper Forums > Model Specific MINI Forums > MINI Cooper > First Generation MINI Cooper
Old Jan 7th, 2003, 02:50 AM
Send a message via ICQ to Griffy
Local Time: 01:04 AM
Australia
Memory Options
Hi all
I was at my local dealers yesterday getting a software upgrade and also some of the the memory options changed.
I have a printed list of what is able to done on my car.
There is one maybe two there that I dont know what they do and neither did the dealer, we were running short on time so didn't get a chance to chase it up any further.
There are 5 Central Locking options all up. The ones we aren't sure of are as follows:
Selective central Locking (factory def is n/a, set to n/a)
active
not active
Selective CL RC (factory def is active, set to active)
active
not active
Dealer seems to think that one of then is for unlocking drivers with one press of key, passenger on 2nd press, which is how mine is currently setup. Were not sure which one that actually is and what the other one does at all ?
They were closed and I had to go so didn't have an opportunity to experiment with it.
Any ideas ??
Old Jan 7th, 2003, 04:02 AM
Andy@Ross-Tech.com's Avatar
Send a message via AIM to Andy@Ross-Tech.com
Local Time: 10:04 AM
Correct on the first one. Selective unlocking means press the MINI symbol once to unlock driver's door, press twice to unlock all doors. I'm not sure, but CL RC could mean Central Locking Remote Control?
'03 MCS every option+Helix/P&D+One-Ball+HAI+Enkei+Falken
The Unofficial MINI 1/4 Mile Dragracing Database
Old Jan 7th, 2003, 04:18 AM
Australia
yes since found out the CL RC is in fact remote control and being active requires 2 presses to open both doors.
Now I need to know what the other one does, maybe the same thing for the console switch ?? seems a bit silly to have to operate it twice if your actually sitting in the car ?
anyone ?
Old Jan 7th, 2003, 02:53 PM
The printout of the memory option should be broken down by category, with each option listed under the category heading. Something like Doors, windows/sunroof, units of measure, etc.
Which category on the print out is
"Selective central Locking (factory def is n/a, set to n/a)
active
not active " under?
If it is under the windows/sunroof category it is the option to open the windows/sunroof by holding up the central locking button.
Old Jan 7th, 2003, 03:00 PM
Paul's Avatar
MINI2 No.1
Local Time: 02:04 PM
England Male
Re: Memory Options
active
not active
active
not active
My guess.
Top one is turn key in lock once to unlock just drivers door, unlock via the lock again to unlock passenger door.
Bottom one is unlock drivers dooe with one press of the remote, two presses ulock both doors.
The setting for key in lock and key buttons can be different for things like comfort opening/closing, so I do not see why there wont be two setting for selective central locking too. One for 'key in the door' and one for 'remote control'.
memory options GirlyMini First Generation MINI Cooper 1 Apr 20th, 2007 04:53 PM
R56 memory options Martin F Second Generation MINI Cooper S 16 Dec 22nd, 2006 10:33 AM
List of Programming Options (Memory Options) Genevieve General Discussion 3 May 11th, 2005 03:06 AM
Changing Memory options rEXC General Discussion 0 Apr 9th, 2004 07:37 AM
changing memory options, how much? KAMAKAZI General Discussion 3 Jul 17th, 2003 09:08 AM
