No gear indicator CVT - MINI Cooper Forum
post #1 of 2 (permalink) Old May 27th, 2014, 01:55 AM Thread Starter
Local Time: 04:19 AM
United States Male
Hello everyone,
I have a 05 MC CVT. I am having an issue with my gear indicator. When I start the car it wont show "P" (park). Same thing happens with Reverse and N. But when I go to drive it shows "D" like it should also if I move the lever over it shows "SD".
Some times it will show all gears and sometime not and when it does not show PRN then when I put into drive it slams hard. I do no that the previous owner dropped coffee on the gear lever. So I cleaned it well but still the same.
I think its the Trans shift selector switch (but that's not what it is called)? PRNDL switch
Thank you
Vxmini is offline
post #2 of 2 (permalink) Old May 29th, 2014, 03:27 AM Thread Starter
United States Male
Ok just incase anyone has this is. It was due to Coffee or Soda that spelled in the cup holder area and leaks down on the PRNDL input and fries it.
you can get this part from MINIMANIA for $80.00 or got to the dealer and pay $760.00 for the entire shifter assembly
Vxmini is offline
High engine rev on lift off in 6th gear (CVT) shininghero First Generation Faults & Fixes 3 Oct 23rd, 2015 02:05 PM
HELP!! i lost 6th Gear GreekDrifter91 First Generation MINI Cooper S 2 Feb 27th, 2013 05:49 PM
Banging when setting off,noisy gear change lee and pip First Generation Faults & Fixes 2 Aug 20th, 2012 06:18 PM
Mini Cooper S Diesel Convertible Gear Lever Linkage Disconnect mbennette Second Generation Faults & Fixes 0 Aug 20th, 2012 01:13 PM
my gear box/cluth? missminicooper Welcome New Members 1 Aug 13th, 2012 09:29 PM
