Oil Pressure Sensor Switch - 2002 Cooper - MINI Cooper Forum
post #1 of 2 (permalink) Old Jun 17th, 2014, 02:25 PM Thread Starter
Local Time: 06:37 AM
England Oil Pressure Sensor Switch - 2002 Cooper
Hi everyone,
Does anyone know where I can get hold of an oil pressure sensor switch online or the South East area of Kent?
I've got the oil warning light on at idle and have been told to change this as a first step.
Thanks!
lucass_247 is offline
post #2 of 2 (permalink) Old Jun 28th, 2014, 01:30 AM
Local Time: 10:37 PM
DIY
Originally Posted by lucass_247 View Post
Hi everyone,
Thanks!
If you are not having any low oil pressure symptoms, i.e. valvetrain noise, try the following: make sure your oil filter is OEM style and that the media is installed correctly (Black Rubber ring towards engine, not top of the canister) that may solve your pressure light situation.
Benjaminbvi is offline
Tags: , , , , , , ,
Oil Pressure Sensor Switch - 2002 Cooper lucass_247 First Generation Faults & Fixes 1 Jun 17th, 2014 05:10 PM
Cooper S R53 serviced, MOT'd, oil changed and it just started leaking oil wizen First Generation Faults & Fixes 4 Jun 5th, 2014 06:37 PM
Best Type of Oil for 2002 Mini Cooper Jammer107 Maintenance & MINI Care 2 May 20th, 2014 07:04 AM
Low Oil Pressure - Filter Debris in Oil System??!! MissMac General Discussion 5 Apr 1st, 2013 11:23 AM
2006 Cooper R50: Oil and Tire Pressure rphox2003 First Generation MINI Tuning 3 Mar 16th, 2013 03:46 PM
