Warning Lamp on, help! - MINI Cooper Forum
post #1 of 4 (permalink) Old Aug 6th, 2014, 07:30 PM Thread Starter
Local Time: 02:22 PM
England Warning Lamp on, help!
My wifes 2003 Mini Cooper has a warning lamp on the centre console. It is the 3rd light from the left above the handbrake light. It is a yellow circle with 3 dashes on either side, there is no exclamation mark in the middle.
I cant seem to find it in the owners manual or online. I initially thought it was a tyre pressure warning, so I checked the tyres and inflated accordingly, I then tried to reset using the button below the handbrake, key position 2, hold button, start engine and drive off I have also tried it with the engine running but no luck, the light stays on!
Any help would be much appreciated.
Neil.Cann is offline
post #2 of 4 (permalink) Old Aug 6th, 2014, 11:06 PM
mab01uk's Avatar
Local Time: 01:22 PM
Quoted: 2 Post(s)
Brake Pads are worn warning light.
mab01uk is offline
post #3 of 4 (permalink) Old Aug 7th, 2014, 05:21 AM Thread Starter
Thanks, I think!!
I did check the pads and they look like they have plenty left on them so ruled it out. Looks like I have a new job for the weekend.
Thanks again for your help.
post #4 of 4 (permalink) Old Aug 7th, 2014, 08:18 AM
Quoted: 83 Post(s)
The inside pad wears quickest, so unless you took the wheels off you may have missed it.
k3fus is online now
2010 clubman - brakes warning light dwheelie Maintenance & MINI Care 0 Mar 13th, 2014 05:40 PM
Battery warning light, overheating warning light LizzyG Second Generation Faults & Fixes 2 Jan 2nd, 2014 05:30 PM
Warning lights lit again! minidriver_one First Generation MINI One D 1 Nov 23rd, 2013 04:53 PM
Low Press Warning (The Age Old Question) haiax0 General Discussion 3 Nov 23rd, 2012 11:43 AM
Multiple warning lights on start up Sparkling Silver Second Generation Faults & Fixes 8 Oct 19th, 2012 02:48 PM
