| First Generation MINI Cooper MINI Cooper from 2001 - 2006 |
| Re: Cooper w/ SSP: rear sway bar Yes: SS 16mm - 33556754818 SS+ 17mm - 33556754819 both take the same bushing. for the front SS is 22.5mm and SS+ is 24mm with different bushings. The SS+ struts are the same as the Cooper S struts. The springs are determined by the car weight rather than whether it's SS or SS+. here's a link with the other part #'s: http://omor.com/mini/ss_vs_ssp.php ![]() |
| Thanks for the responses and information, cristo and Paul. Apparently, the S bar will fit a Cooper if you tighten it down. Many S owners are upgrading to an aftermarket adjustable rear sway bar, so it's possible to pick up a used S bar for a reasonable price. It seems like all the aftermarket sway bars fit both the Cooper and S, since there is only one part number per bar type. I will contact my dealer about the Cooper ssplus bar. |
| Rear Sway Bar for the GP ? | Chief_Charlie | First Generation Works | 1 | Dec 5th, 2006 09:50 AM |
| Rear Sway bar | Stats | First Generation MINI Suspension | 2 | Jul 5th, 2006 10:52 PM |
| Rear Sway Bar / Anti-roll Bar | DragonSean | First Generation MINI Suspension | 7 | Apr 20th, 2004 04:17 PM |
| Cooper rear sway (anti-roll) bar upgrade | GregF | First Generation MINI Suspension | 0 | May 6th, 2003 08:56 AM |
| Rear Sway Bar | ghillie | First Generation MINI Suspension | 35 | Apr 2nd, 2003 09:34 AM |
