| First Generation MINI Cooper MINI Cooper from 2001 - 2006 |
Engine Revs @ 70 mph Can anyone tell me what engine revs the Mini Cooper manual is showing on a relatively flat surface at a constant 70mph ? I just want to compare to my CVT Auto Cooper (which is about 2900 revs at 70mph. Thanks. |
| Theoretically: 5th - 3290 4th - 4064 3rd - 5148 2nd - 7548 1st - 13237 Above are calculated with 15" wheels. Cooper with CVT would be 5th - 3382 4th - 4178 3rd - 5292 2nd - 7758 1st - 13607 I used the following website to calculate: http://www.xse.com/leres/bin/gearrat...mference=75.26 and http://www.web-cars.com/math/tiresize.html to calculate the tyre circumferance. Gear ratios are in the MINI brochure. If you are just reading off the speedo to compare to the revs, it overstates the speed significantly at above 60mph. Best way to get accurate speed is with a GPS. |
| PMM, thanks for that. The CVT has 6 'virtual' gears, but I presume thats not the whole story as the revs can vary depending on whether your in Drive, Sport Drive or Manual mode. Ill have a look at the manual and see if I can make sense of it. |
| Since I got the JCW kit a few weeks ago, 2nd has turned into a killer gear. ![]() Good for anywhere between 20 and 70. The JCW kit just smoothed out the whole range and made it so much more usable. JCW S, IB/W, Lapis Blue, sunroof etc. |
| Engine Revs When Take Foot Off Gas | hanelin | First Generation Faults & Fixes | 2 | Apr 22nd, 2007 12:54 AM |
| 0 - 60 mph for MCSc with JCW engine upgrade | jrozario | First Generation MINI Convertible | 4 | Mar 25th, 2006 01:58 PM |
| Engine revs high after alignment/tire rotation | kendertaunt | First Generation Faults & Fixes | 12 | Oct 19th, 2005 10:22 AM |
| Engine revs to about 2000 rpm when starting | Scoobystu | First Generation Faults & Fixes | 5 | Jul 21st, 2005 09:20 PM |
| revs | supercooper_07 | First Generation CVT & Automatic | 3 | Oct 9th, 2004 01:56 PM |
