Handling problem when I have sub in boot! - MINI Cooper Forum - MINI2 Mini Cooper Forums
Go Back   MINI Cooper Forum - MINI2 Mini Cooper Forums > Model Specific MINI Forums > MINI Cooper > First Generation MINI Cooper
Old Jan 15th, 2004, 02:08 PM
Spoony's Avatar
Send a message via MSN to Spoony
Local Time: 03:06 PM
England Male View Spoony's Solid Black & Body Color 1st Gen MINI Cooper S Profile View Spoony's Classified Ads
England Handling problem when I have sub in boot!
Hi
I've had a quick look at previous posts on this but was unable to come up with anything.
About six weeks ago now I had a little, ah hum, mishap whilst driving home from work, the mishap being that I lost control of my ONE around a left hand bend and jack-knifed the car into some trees, nobody was hurt thankfully which is the main thing but the car was pretty battered (see photo gallery).
As a replacement of my ONE I have recently bought an Indi Blue Cooper with all the toys gadgets and gizmos etc which I managed to buy from the write off value I got from the ONE (and paying a little bit more towards it of course).
Anyway I'll get straight to the point of this thread.
My ONE had a sub in the boot which was fine, no handling problems etc. But whilst driving home from work this afternoon I felt a huge difference in the handling of the car, it felt as though there was so much weight at the back that the front wheels were barely able to gain any decent traction, this I found quiet hair raising. It would seem logical that if there is alot of weight at the back of the car then there wont be as much traction at the front, but I never experienced this problem when I had my ONE. It may well be the suspension, my ONE had the sports suspension and the Cooper has sports suspension plus (maybe the same thing?), the size of the wheels I had on the ONE were 15", the Coopers 17".
So has anybody had a similar problem or is it just my imagination?
Spoony
Old Jan 15th, 2004, 02:52 PM
Local Time: 02:06 PM
United Kingdom View barrie74's Chili Red & White 1st Gen MINI Cooper Profile
Might seem obvious
Have you changed the tyre pressure to accomodate the load of the Sub, I'm sure I remember reading in the manual that there is a different set of pressures for loaded and unloaded this will probably increase the down forse at the front. I would imagine that you will notice it more with the SS+ suspension because I feel you get a much better feel of the road with the SS+
Old Jan 15th, 2004, 02:55 PM
obehave's Avatar
Mini Mod
Local Time: 10:06 AM
Take the sub out and do the exat same thing and see if there really is a difference or is this just the first time you noticed.
No mention of tire pressures. Did you verify they are correct?
You there shouldn't be a negative to having the sub in your boot. Can't see why SS+ should feel worse than SS. It's a pretty subjective thing as well so it's pretty hard to say right or wrong.
Old Jan 15th, 2004, 03:37 PM
Skinnyrunt's Avatar
M2 Bapmaster
Send a message via AIM to Skinnyrunt Send a message via MSN to Skinnyrunt
United Kingdom View Skinnyrunt's Pure Silver & Black 1st Gen MINI Cooper Profile
Can't see why having a sub in the rear should affect the car this much....unless it's one of those clarion 32 inchers
Old Jan 16th, 2004, 07:18 PM
Spoony's Avatar
England
Thank you for your comments guys but it looks as though I will never be able to fully resolve this problem.
There is definitely a very noticeable difference in the handling of the car and im certain it comes down to the different suspension on the car, if its not the suspension then im a little perplexed as to what else it can be, after all I did not have this problem in my ONE.
The tire pressures are spot on so no problems there, but Barrie, when you say 'Have you changed the tire pressures to accommodate the load of the Sub' do you mean I should try deflating them?
The subs not quiet a 32 incher , its a 15" Kicker Solo Baric. Lol if anyone manages to fit a 32 incher in their Mini I will eat my hat, if anyone has achieved or achieves this in the near future, please feel free to email me with pics and I will gladly eat my hat live on web cam,
Spoony
Old Jan 16th, 2004, 07:36 PM
NEMINI.org
Local Time: 09:06 AM
United States View NEMINI's Silk Green & Black 1st Gen MINI Cooper Profile
The more weight in the car the higher the pressures should be. In the manual it gives two pressures, one for unloaded and one for loaded
Old Jan 16th, 2004, 09:00 PM
andyupnorth's Avatar
There's no way the installation of a sub in the boot would affect the handling - not unless it weighed an absolute tonne.
Old Jan 16th, 2004, 11:31 PM
Root Ginger's Avatar
Amiga 500 to PS3 20 Years
There is an obvious thing you are missing here folks, for the difference in handling.
a. Wheel size makes a big difference and more importantly...
b. Run-Flats
Am I right in thinking you now have run-flats and the one wouldn't have.
It's already be commented on that changing from run-flats to non run-flats makes a massive difference in the grip and handling of the car. Therefore the opposite would be true and I suspect this is what you're experiencing.
It was acceptable in the 80's
Old Jan 17th, 2004, 12:17 AM
United Kingdom View MINIALEX's Dark Silver & White 1st Gen MINI Cooper S Profile
how heavy is the sub, i've had a bootful of loads of really heacy stuff, i.e. full of lager and I mean full and there was very little effect, The egneral concensus on here is that the car handles a lot better with a full tank of petrol so weight at the back should be fine
PS Yes my car did have SS +
Cometh the Hour, Cometh the MINI
Old Jan 17th, 2004, 12:33 AM
wils's Avatar
formerly known as wsw
Local Time: 12:06 AM
Hong Kong Male View wils's Chili Red & White 1st Gen MINI Cooper Profile
erm don't cars handle BETTER with more weight in the back? i would have thought they do....dunno just a thought
i got an exhaust because i wanted to make my car sound fast, but its not fast at all, so therefore i am a ricer....
Old Jan 17th, 2004, 06:43 AM
AuthiMini's Avatar
Local Time: 07:06 AM
United States View AuthiMini's Indi Blue & White 1st Gen MINI Cooper S Profile
Talking
Well it would if it were a submarine! :-)
Old Jan 17th, 2004, 09:54 AM
LMAO
60-70mph weird handling problem TallAndy Wheels, Tyres & Brakes 13 Jan 12th, 2007 07:43 AM
wheel and handling probleM? adoreableyuja First Generation MINI Cooper S 7 Sep 15th, 2006 06:42 PM
cooper s handling problem HELP...!!! yiano First Generation MINI Cooper S 4 Oct 13th, 2004 10:12 PM
Handling problem? leon1982 First Generation MINI Suspension 4 Mar 28th, 2004 08:17 AM
Boot / TrunkOrganizer Problem Bibendum First Generation Faults & Fixes 7 Apr 22nd, 2002 01:24 PM
