Traction Control - MINI Cooper Forum - MINI2 Mini Cooper Forums
Go Back   MINI Cooper Forum - MINI2 Mini Cooper Forums > Model Specific MINI Forums > MINI Cooper > First Generation MINI Cooper
Old Mar 27th, 2002, 08:53 PM
Local Time: 02:07 PM
Question Traction Control
Hello, just a question.
Since DSC is more expensive than ASC+T I take it ASC+T is included (or integrated) into DSC?
Old Mar 27th, 2002, 09:59 PM
noahe's Avatar
Send a message via ICQ to noahe
Local Time: 10:07 AM
Canada View noahe's Chili Red & White 1st Gen MINI Cooper S Profile
Although a completely different system, DSC provides all the functions, or equivalent of ASC+T. The Cooper S I drove in a snow storm, definately had Traction Control as part of the DSC system.
Chilli Red/White Cooper S, Sport Pack & Sunroof. Delivered June 12th, 2002!
Now with MCS Winter Tire Package.
Old Mar 28th, 2002, 07:34 PM
Thanks. That's wat I suspected, just didn't know quite how they compared.
Old Apr 2nd, 2002, 04:45 PM
ELISEBOY's Avatar
Send a message via ICQ to ELISEBOY Send a message via Yahoo to ELISEBOY
Local Time: 03:07 PM
England
so can someone clear this up
does that cooper come with any form as standard?
I have the ASC+T whcih i paid extra for and thought this was the full system
is there a DSC as well then cause i didnt see this in the options list?
Old Apr 2nd, 2002, 04:59 PM
As standard, the Cooper comes with anti-lock brakes including Electronic Braking Distribution and Cornering Brake Control. This does help cornering while braking - I have experienced it - its wierd but good!
DSC was not available until fairly recently, and wasn't on the first options list.
Old Apr 2nd, 2002, 05:03 PM
noahe's Avatar
ASC+T is All Season (traction) Control.
I have also heard this called "Automatic Stability Control, plus Traction Control". It basically prevents your car from skidding due to excessive acceleration. It will apply the brakes and reduce engine torque in order to reign in control.
DSC is Dynamic Stability Control. It incorporates the function above, as well as utilizes yaw sensors, wheel speed sensors, and steering angle input, to determine if the car is skidding out of control. This system, one up from ASC+T prevents oversteer, understeer, and just about any other skid you could get yourself into. It can apply any one or more of the brakes, as well as route more engine torque to one front wheel over another.
There is a LOT of info on this... Search DSC, right here on MINI2.
Old Apr 2nd, 2002, 11:31 PM
karmuze's Avatar
There was a great deal of discussion of DSC and ASC+T back in January and February. One of the BMW websites contains a brief description of both and was referenced in this post:
http://www.mini2.com/forum/showthrea...t=54#post35268
The simple way I try to keep them straight is that:
ASC+T acts to prevent the front wheels from spinning under acceleration by applying the brake on the spinning drive wheel, then reducing the engine throttle if more action is still required.
DSC in addition, acts to prevent loss of control during cornering or sudden steering maneuvers by applying the brake on any combination of all four wheels and also reducing the throttle if necessary.
Originally posted by noahe
DSC can apply any one or more of the brakes, as well as route more engine torque to one front wheel over another.
noahe, from what I've read on the subject, everything you said above is accurate except I don't know how DSC can send more torque to one drive wheel, since no MINI model has a limited slip differential.
Jerry
Old Apr 3rd, 2002, 01:16 PM
noahe's Avatar
Since the DSC system can moderate, and apply the brake to a threshold, by braking one wheel, more torque will be applied to the unbraked wheel. In a severe oversteer condition, the MINI's DSC could have the front left tire just on the verge of locking (actually rotating slower than the road) and the front right tire just on the verge of slippage (slightly spinning). The effect of which is to drag the car around a corner, it otherwise wouldn't make, steering it's self like a Bobcat construction shovel or a tank does.
Another example would be if one of the car's front wheels was on ice. The wheel not on ice would move the car, and the other one would be braked to the extent that it just rolled along with the car. There's no torque-sensing differential, but it utilizes the brakes and a real fancy conputer to achieve the same results.
Old Apr 4th, 2002, 02:00 AM
karmuze's Avatar
noahe, thanks for the clarification. But your explanation brings up a drawback I see for the DSC option. That is, that it only operates unilaterally--it slows the car by applying individual brakes, and also slows the car by reducing throttle or timing. It doesn't ever increase the throttle to allow the front wheels to accelerate the car out of an oversteer situation like you described above.
I know I've have saved the FWD car I drive in one situation where the back end started to come around, by doing the opposite that DSC would do--I accelerated, stayed out of the brakes, and cranked in a small amount of opposite lock.
The driver of a non DSC car has the option to use the throttle or brakes independently or together. DSC takes those options away from the driver. I know the amount of control that DSC exerts is programmed into the computer at the factory, and I don't know how intrusive or annoying the MINI DSC would be to my driving style, since it would probably take serveral months of ownership to determine that.
The other question I have wondered about, is whether any aftermarket tuner has ever considered selling custom DSC programming to suit the individual driver, as they do with custom programming of the engine management computer to increase the engine performance.
Jerry
Old Apr 4th, 2002, 10:40 AM
noahe's Avatar
Well, I see your point, but disagree to a certain extent. Firstly, you can switch off DSC, and drive any way you like.
Secondly, if you felt it get loose in a corner, you could mash the accelerator and attempt to pull the car around, but the DSC will do one better, and make sure the outside wheel does the pulling, not both. The DSC does not always slow the car down to achieve it's goals. It uses the steering position, yaw sensor and other wheel speeds to determine if the car is going to make it. True, I doubt it is able to apply the throttle it's self, but if you do, it'll use it.
Think of it this way. The system is designed to get the car to do what you intended, based on driver input. If you panic, let off the gas, or even hit the brakes, it'll use what is has (brakes) to recover the car. If you aggressively roar into a corner, it'll brake the inside wheels, forcing power to the outside wheel, pulling you around that way. It's a drivers' aid. It's been proven in racing. If it always saved a car by slowing it, no one would win races.
Better to say this... It can optimize the speed of a car through a severe maneuver. It ultimately leads to the car going faster than slower. But without a four-wheel, white-knuckled slide through the corner, does it feel faster? Maybe not. But it is.
Name:	yaw control.jpg
Old Apr 9th, 2002, 06:09 PM
groovy_jr's Avatar
Send a message via AIM to groovy_jr Send a message via Yahoo to groovy_jr
United Kingdom View groovy_jr's Cosmos Black & White 1st Gen MINI Cooper Profile
Right...I am having DSC!
*ORDERED*
Traction Control on/off Adamm1985 General Discussion 3 Jul 11th, 2007 05:51 PM
Traction Control Adrian_T First Generation MINI Tuning 20 Mar 29th, 2006 04:11 PM
Traction Control Angel_1701 First Generation Faults & Fixes 0 Dec 17th, 2005 12:25 PM
Traction Control Wooly First Generation MINI Cooper 17 Sep 9th, 2005 06:11 PM
Who needs traction control...... Charger_Pete General Discussion 18 Oct 29th, 2004 03:19 PM
