| Be aware that with either version, the chrome coating does block about 30% of the available light. On the Sylvania version in the US, they use a 27-watt filament to compensate. If you are using a 21-watt chromed bulb, you are getting the light equivalent of a 15-watt bulb, i.e. significantly dimmer than stock. I haven't found any 27-watt non-chromed replacement bulb for the 7507 bulbs, and there is no US-equivalent bulb number. |
| That may be the case OldRick, but I can't say that, in Australian conditions at least, the light given from the Silvervision globes would cause any problems. IMO the only way you could prove any light blockage would be by undertaking a proper scientific test, certainly with the naked eye I doubt you would be causing anyone any problems. |
| Tags: diadram, osram, phillips |
LinkBacks (?)
LinkBack to this Thread: http://www.mini2.com/forum/first-generation-mini-exterior/100129-phillips-silvervision-osram-diadem.html | ||||
| Philips SilverVision sinyal lambalar - ClubSkoda Trkiye Fan Sitesi | This thread | Refback | Apr 4th, 2009 11:14 PM | |
| Diadem Bulbs?? | JHorwitz | First Generation MINI Exterior | 26 | Nov 30th, 2006 09:27 PM |
| Anyone fitted diadem bulbs? | Cobby Park Lane | First Generation MINI Exterior | 9 | Nov 30th, 2006 01:49 PM |
| Phillips Blue Vision Bulbs ;) | AJH3 | First Generation MINI Exterior | 50 | Jan 11th, 2004 12:42 AM |
| Osram Diadem Indicators | Root Ginger | First Generation MINI Exterior | 10 | May 13th, 2003 02:06 PM |
